No alarms from BE600M1 with low battery
Send InviteCancel
Posted: 2024-01-0501:16 PM. Last Modified: 2024-01-0501:23 PM
I have a 2 year old BE600M1 UPS that has been fine thus far. It powers a small file server and my network hardware for about a 20 minute backup.
I had an outage today and I noted the UPS was up about 5 minutes later but then went down 10 or so minutes after that with no alarms.
When the utility power was restored and there was a solid green power LED on the UPS, I powered up the file server. It almost immediately shut itself back down. I then disconnected the USB monitoring cable and brought the file server back up. I found the page to monitor the UPS, and plugged the USB cable back in. When the page refreshed, it showed a 1% battery level and shut the server back down again.
I power reset the UPS, but nothing changed. There were never any alarms.
Does the lack of alarms indicate there's a problem with this unit other than a low battery?
Posted: 2024-01-2209:24 AM
Based on your description it sounds like the UPS is programmed to mute any audible alarms. Please refer to the *On Battery Indicator* modes which there are three. There are three options in how the UPS will react while on battery power.
