No AC after changing battery in Back-UPS RS 1500
  • No AC after changing battery in Back-UPS RS 1500
2151
123
Posted: ‎2021-06-29 08:20 PM . Last Modified: ‎2024-03-21 12:54 AM
1571
I just replaced the battery in my Back-UPS RS 1500.  When I connect to AC and press the power button it will ONLY operate on the battery.  It's as if I never connected to AC.  I have tried multiple outlets all of which are working with other items.  No luck.  No evidence of damage to the AC cord or anything else.  The Unit was operating normally until previous battery became unchargeable.
  • 1500
  • back-ups
  • replacement
Posted: ‎2021-06-29 08:20 PM . Last Modified: ‎2024-03-21 12:53 AM
Hello Alexandre,
I am sorry that you are having an issue.
I am a little confused about exactly what model you have, the BR1500 is an older model Back-UPS, which does not have sensitivity settings. Do you have a BR1500G? What is the serial number?
Typically, 128V is a little high, but if you have sensitivity set to low, then it should be fine. Also, depending on the model, it is also too low for the AVR trim to turn on.
Do you know what voltage the fluke measured incoming voltage as?
Shanon
So is this a BR1500 or BR1500G (the G has the front panel LCD)? I am just wondering if you can see on the LCD if it shows 0V input voltage?
If not, do you have PowerChute Personal Edition installed so we can try to figure out why it is not going on battery (THD/electrical noise, voltage out of range - or it thinks it is but it is not, etc).
I have same problem.
My Smart UPS BR1500 120V not recognizes AC; In Powerchute (Windows) i see AC power as 128V; Sensibility is set to LOW.
After power ON, GREEN LED (ON LINE) blinks six times while YELLOW LED (BATTERY) is solid. In a few seconds it goes to battery mode and GREEN LED if off.
Only operates at battery mode. I got a test on AC POWER LINE using Fluke meter and it is OK.
Thanks for any help
Alex
Hello Alexandre,
Shanon
