Need a UPS of about 1500 va which will NEVER BEEP
  • Need a UPS of about 1500 va which will NEVER BEEP
2151
123
Posted: ‎2021-06-29 09:32 PM . Last Modified: ‎2024-03-20 04:10 AM
1879
Hi all.
This UPS is used ONLY to provide power to a night time CPAP (1.5 amps) if/when the electricity goes off. Because this UPS is being used on a device that helps sleeping, I cannot have a BEEP if/when the home electricity goes off.
This UPS is NOT being used for a computer and will never be used for a computer or anything which requires a "shut down". It is only being used for a night time sleeping device.
QUESTION: Is there a good UPS unit which will not BEEP if/when the home/business electrical supply is interrupted ? Or is there a UPS which can be easily modified not to beep when the UPS unit must be the sole supplier of electricity to the attached device ?
Thank you.
  • Universal Transfer Switch
Posted: ‎2021-06-29 09:33 PM . Last Modified: ‎2024-03-20 04:09 AM
5 hours at least yes!
Message was edited by: Matthewop
Replies 5
i think most UPSs will allow you to mute the on battery sounds via software but it wont let you disable certain things such as replace battery or low battery.
I took mine apart and removed the buzzer from the circuit board, It will never ever ever beep...
Posted: ‎2021-06-29 09:32 PM . Last Modified: ‎2024-03-20 04:09 AM
The device to attach to the UPS draws 1.3 amps at the most. If the UPS specs shows 900 watt output, how long will my attached device run ? Seems like at least five hours, right ?
Thank you for all your replies.
Yikes. I just found this document: http://www.resmed.com/us/assets/documents/service_support/battery_guide/19825_battery-guide_glo_eng....
The device is an S9 AutoSet with NO humidifier. The pressure is 14, and EPR is full time at "3". I was told that the draw is 1.1 amps.
Does this document seem to indicate that either of these two UPSs are not advisable ?
Message was edited by: Positron
