NMC AP 9631, cable: 9401525, how to setup hyper terminal connection
Select a Country
  • NMC AP 9631, cable: 9401525, how to setup hyper terminal connection
BillP Leader
2150
150
83
BillP Leader
Leader
Posted: ‎2021-06-29 04:06 AM . Last Modified: ‎2024-03-22 12:57 AM
1917
we have UPS 5000 with AP 9631. I am trying to configure network connection for UPS ...
First try:
I tried to setup network parameters on NMC throug "Device IP Configuration Wizard".
The message was "... ip address is in use ..."
IP is not in use.
Second try:
Use serial cable and connect UPS to machine.
Hyper Terminal connection parameters are (from link: http://nam-en.apc.com/app/answers/detail/a_id/3061😞
I have cable 940 1525 A. Connect it to Universal I/O on UPS and Serial on machine.
Properties of hyper connection:
9600 bps, 8 data bits, no parity, 1 stop bit, and no flow control.
but there is no answer ....
Once with IBM UPS 3000XHV it passed with:
2400 bits per second, flow control Xon/Xof, and disable advanced option on COM properties- "Use Fifo Buffers"
pls for any information I would appreciated it ...
thank you for your time,
Indira
BillP Leader
Leader
First try:
IP is not in use.
Second try:
Indira
Replies 4
BillP Leader
Leader
Hi Indira,
What is the exact model number of your UPS? Also, the AP9631 card comes with another kind of cable it is a serial to TRS (tip-ring-sleeve) and the part number is 940-0299. You can use this cable to access HyperTerminal and the settings would be 9600-8-None-1-No Flow Control. You can also use the 940-0024 or 940-1524 cables and the terminal emulation settings would be 2400-8-None-1-No Flow Control.
JonPro
BillP Leader
Leader
Sorry, double post.
Message was edited by: JonPro
BillP Leader
Leader
thank you JonPro, very, very much.
I found cable 940-0299 (somewhere in box 🙂 ), setup connection as you said, and it works !
I hope that everythin else will be ok.
thank you for you time,
Keli
BillP Leader
Leader
First try:
IP is not in use.
Second try:
Indira
