My Back-UPS ES 600M1 keeps beeping despite "disabled" in powerchute!!!!!
  • My Back-UPS ES 600M1 keeps beeping despite "disabled" in powerchute!!!!!
2151
117
83
Posted: ‎2021-06-28 06:47 PM . Last Modified: ‎2024-03-26 02:55 AM
4470
In Powerchute, the setting is this:
Hhpsjm5uMdhyaU7R6YEwpw%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.pngHhpsjm5uMdhyaU7R6YEwpw%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.png
Yes my goddamn UPS keeps beeping whenever my PC is under heavy load. It seems like this setting does nothing at all. Incredibly frustrating.
You can't disable it, it's there for a reason.
Constantly running a ups in overload is dangerous for both the UPS, equipment and possibly for you.
-Gavan
Replies 5
In terms of the model number, on the bottom it says BE 600M1. In Powerchute it says this:
To be clear it's a long continuous beep that doesn't stop until I shut down the intensive programs on my PC. Does Powerchute just not do anything at all?
Hi Ian,
You say that it only beeps when you are doing heavy work on your computer?
If that is that case then it's probably the overload alarm and not the backup alarm. The backup alarm is only when the power is out, the overload alarm is when you are going beyond the capacity of your UPS.
That particular unit is only good for a peak usage of 330 watts.
-Gavan
Ok so how do I disable the overload alarm beeping? It's very annoying.
-Gavan
