Continue
  • My Subscriptions
  • Events
Is BR1000G-IN enough for my PC
  • Is BR1000G-IN enough for my PC
BillP Leader
2151
156
83
jnraj_apc
jnraj_apc
Explorer
Posted: ‎2021-06-29 09:11 PM . Last Modified: ‎2024-03-20 05:43 AM
2385
Please reply, I would like to connect my high end PC and 27 inch monitor to this UPS (BR1000G-IN).
My specs are
Intel i5-4670k,
Gigabyte Z87- UD3H Motherboard,
Zotac 760 gtx Amp edition Graphic card,
G Skill Trident X - 8 GB DDR3 RAM,
1 Bluray writer,
1 Samsung 840 SSD 120GB,
1 WD Black 1TB
4 internal 140mm cooling fan,
6 USB devices,
PSU - I would use is 600 watt 80 plus gold rated smps, is that enough?
My requirement is a 5 to 10 backup, so that I can save my work and shutdown my PC.
Will the UPS be overloaded by my PC specs, thanks.
  • back-ups
  • br1000g
  • help
  • overload
  • power
BillP Leader
Leader
Posted: ‎2021-06-29 09:11 PM . Last Modified: ‎2024-03-20 05:42 AM
You'd probably want a bit of a buffer for potential overloads when the system is working a little harder at certain times.
Replies 5
BillP Leader
Leader
Have you tried the UPS selector tool? UPS Selector - Select your protection needs
jnraj_apc
jnraj_apc
Explorer
thanks Bill, I will consider the 1500 model. smile
jnraj_apc
jnraj_apc
Explorer
I used the tool, the options are a bit older smile. However I assume my PC will give BR1000G a load >85% . Does this much load affect the UPS lifetime and performance undecided, Thankssmile.
BillP Leader
Leader
I recommend keeping the load at less than 80% so look at the 1500 instead of the 1000. Running at 85% will not affect the lifetime but as the battery ages its ability to sustain the load for X period of time can change.
BillP Leader
Leader
