Posted: โ2025-06-20 12:24 AM
Posted: โ2025-06-20 01:11 PM
You'll need to provide a lot more information if you want a qualified answer. Provide a screen capture of the following from the NMC webpage under the About: NMC / UPS
Provide a photo of the front, back, of the unit clearly showing the serial number of the hardware.
Questions Ask . . . ๐
Posted: โ2025-06-22 06:06 PM
UPS: SRV3KI-E / 441.12CT.I (firmware version)
NMC: AP9544/3 (hardware version)
NMC Application: eu1p / v2.0.0.15 (version)
AOS(APC OS) : aos / v2.1.0.6
APC boot monitor: boot / v1.4.0.2
Please understand that there is no picture of the image containing the serial number because it is judged not to be posted for information protection.
โ
Posted: โ2025-06-23 03:28 AM
What exactly is the history of this unit and the problem?!? Meaning is this a brand new system? If not how old is it and when did this problem begin?
If this problem existed from the beginning I suggest you contact APC Technical Support in your region.
If this problem started after a firmware upgrade to the NMC have you tried updating it to the latest v2.5.1.7:
This appears to be improper NMC firmware loaded on to the system. Please change the language to English as I canโt read what the tabs say.
Doing so will also insure this isnโt a conflict using the language package. Ensure you reboot the NMC once the language is changed to English.
NOTE: You need only provide the first four digits after the letters as it relates to the serial number. Even if you provided the entire serial number there is NO PI information the general public can access, use, etc.
Youโve reached the end of your document
