How much power does a UPS use to recharge?
Select a Country
  • How much power does a UPS use to recharge?
BillP Leader
2150
150
83
Posted: ‎2021-06-29 06:33 PM . Last Modified: ‎2024-03-21 03:38 AM
3532
Can someone tell me how much power a typical UPS would use while charging. Specifically, I need to know how the charging cycle works once a UPS has kicked in during a power loss and now has had its power supply restored so that it is now in "recharge" mode. I am trying to estimate power usage/needs for an emergency generator. For instance, if we have a power outage and roll out then start up a generator, will the UPCs running off of that generator use the kind of power I think they might? (It looks like a 120V, 12A UPC would charge at 1440 watt load.). Thanks.
  • Universal Transfer Switch
Replies 4
TheNotoriousKMP_apc
TheNotoriousKMP_apc
Contributor
Tom,
Can you provide a few base model numbers. The capacity differs based on the UPS, and I should be able to look up the information for you.
TheNotoriousKMP_apc
TheNotoriousKMP_apc
Contributor
The 1400 would use 136W for the battery charger.
Are there any other UPS's where the sepcs can be referenced for either yourself, or the thread starter
According to APC Doc #504, the Matrix UPS charging power is as follows:
1-2 smartcells: 500 watts
3 smartcells or Smartcell XR : 1000 watts
This is a large amount of charging power - which is why one has to keep close eye on the battery health of Smartcells; if they start getting resistive there is enough charging power to totally melt the cells down...resulting in cracked / swelled cases, clear white "acid" and internal corrosion.
Dave
