[Help]Smart UPS BK650-CH frequent communication failure with Buffal NAS LS-QVL
  • [Help]Smart UPS BK650-CH frequent communication failure with Buffal NAS LS-QVL
2150
127
Posted: ‎2021-06-29 08:19 PM . Last Modified: ‎2024-03-21 12:54 AM
1283
Connecting the BK650-CH UPS with a NAS Buffalo LS-QVL which running on a Linux,,I met the following issue after running some hours( duration < 3 hours):
   1.  Enalbe the "Synchronization with UPS" option on the admin WebUI;
   2.  "USB Connection Type" only has one option which is “USB Port(APC Style)”--So ,I guess this buffalo NAS should have passed a sort of certifcation with APC UPS as the screenshot:
   3.  Max 3 hours after "Synchroniztion with UPS" has been enalbed successfully, the NAS will enther a "fake-crash" state which means all the LEDs display correctly so I can say functionalities should be ok ,meanwhile I CAN PING the NAS successfully via PC, but I CAN NOT login to its WebUI and I can NOT power off the NAS by pressing power key--so I can't ensure the embeded functionalities is working correctly or not;
    4. The only thing  I can do is to remove the plug from the outlet at this time.
    5.  After the NAS has been re-powered on, I can check the kernel log as attached below;
   6. If I disable the "Synchronization with UPS" , the NAS can work correctly for at least 2 days( the lognest duration I tested )
  The ps information in the kernal:
   The kernal log is:
May 23 07:48:18 SeanMediaRepo upsd[24812]: Data for UPS [ups] is stale - check driver
May 23 07:48:40 SeanMediaRepo upsd[24812]: UPS [ups] data is no longer stale
May 23 07:48:40 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 07:48:40 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost lost
May 23 07:49:12 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost established
May 23 07:49:44 SeanMediaRepo upsd[24812]: Data for UPS [ups] is stale - check driver
May 23 07:49:44 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 07:49:44 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost lost
May 23 07:49:44 SeanMediaRepo upsd[24812]: UPS [ups] data is no longer stale
May 23 07:49:44 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost established
May 23 07:50:04 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Server disconnected
May 23 07:50:55 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost lost
May 23 07:50:57 SeanMediaRepo upsmon[24810]: Set username on [ups@localhost] failed: Server disconnected
May 23 07:50:57 SeanMediaRepo upsd[24812]: User admin@127.0.0.1 logged out from UPS [ups]
May 23 07:50:57 SeanMediaRepo upsd[24812]: write() failed for 127.0.0.1: Broken pipe
May 23 07:51:46 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Driver not connected
May 23 07:51:59 SeanMediaRepo upsd[24812]: UPS [ups] data is no longer stale
May 23 07:52:27 SeanMediaRepo upsd[24812]: write() failed for 127.0.0.1: Broken pipe
May 23 07:52:32 SeanMediaRepo upsd[24812]: User admin@127.0.0.1 logged into UPS [ups]
May 23 07:52:32 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost established
May 23 07:52:32 SeanMediaRepo upsd[24812]: Data for UPS [ups] is stale - check driver
May 23 07:52:35 SeanMediaRepo upsd[24812]: UPS [ups] data is no longer stale
May 23 07:53:02 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 07:53:26 SeanMediaRepo upsd[24812]: Data for UPS [ups] is stale - check driver
May 23 07:53:26 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost lost
May 23 07:53:26 SeanMediaRepo upsd[24812]: UPS [ups] data is no longer stale
May 23 07:53:26 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost established
May 23 07:53:26 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 07:53:30 SeanMediaRepo last message repeated 4 times
May 23 07:53:30 SeanMediaRepo upsd[24812]: UPS [ups] data is no longer stale
May 23 07:55:04 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost established
May 23 07:55:56 SeanMediaRepo upsd[24812]: Data for UPS [ups] is stale - check driver
May 23 07:57:42 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 07:57:42 SeanMediaRepo upsmon[24810]: Communications with UPS ups@localhost lost
May 23 07:58:14 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 08:01:25 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 08:06:19 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 08:17:05 SeanMediaRepo upsmon[24810]: Poll UPS [ups@localhost] failed - Data stale
May 23 08:29:56 SeanMediaRepo syslogd 1.5.0: restart.
May 23 08:29:56 SeanMediaRepo kernel: klogd 1.5.0, log source = /proc/kmsg started.
May 23 08:29:56 SeanMediaRepo kernel: Cannot find map file.
May 23 08:29:56 SeanMediaRepo kernel: Loaded 35316 symbols from 10 modules.
May 23 08:29:56 SeanMediaRepo kernel: Booting Linux on physical CPU 0
  • bk650
  • communication
  • failure
  • linux
  • ups
We can help you support the UPS side of this but we don't know the Buffalo NAS - have you reached out to Buffalo yet?
