Es750 master outlet
Select a Country
  • Es750 master outlet
BillP Leader
2150
144
Techie_apc
Techie_apc
83
Posted: ‎2021-06-29 09:13 PM . Last Modified: ‎2024-03-20 04:25 AM
1038
Es750 master outlet
I powered down ups for several days and then powered it back up to find the master outlet power is lost. I can detect voltage but once I plug in the computer it gets no power. is there a reset I need to perform to get the outlet out of its trip mode?
BillP Leader
Leader
Sorry for the delay. In the user's guide, there is reference to working with master/controlled outlets and how to enable and disable.
http://www.apcmedia.com/salestools/KBOK-766PMZ/KBOK-766PMZ_R2_EN.pdf
You can also try resetting the unit and starting over. To do this, turn off any attached load plugged into the UPS and remove it. Turn off the UPS itself and unplug it from the wall. Then, disconnect the battery in the UPS and hold down the power button for 20 seconds. Reconnect the battery, plug the UPS back in, turn it back on, and follow the instructions on enabling/disabling master controlled outlet.
Hope that helps.
BillP Leader
Leader
Hope that helps.
