ES 750 Failing
  • ES 750 Failing
2151
119
83
Posted: ‎2021-06-29 03:46 AM . Last Modified: ‎2024-03-22 01:13 AM
839
ES 750 Failing
I'm working on a 2 station setup connected to the ES750. My boss had this set up and had the monitors, towers hooked up to it. All of a sudden recently it has been Shutting down with a constant tone. I am simply at a loss figuring out how this happened or what to do about it. When I turn it off and back on i get a red led flashing of the battery as if the battery is drained but we havent had any power outages or issues. Help?
Hi the problem that you are having is because this unit be750g came with a special feature of energy saving, the way that it works is that you usually connect the cpu into the master plug and monitor, speakers, printer in to the other 3 plugs (white rectangle) and when you shut down the system, everhing connected into the other plugs part of the white rectangle, will automatically shutdown, this way you avoid energy lost, ghost connection, you can disable the feature with the software and whit the button of master enable/disable or by connecting the device you dont want to get off into a different plug outside of the white rectangle
