Control ups output on/off from remote server without web
  • Control ups output on/off from remote server without web
2150
127
ljw
ljw
Cadet
Posted: ‎2024-10-11 01:37 AM
573
Im using APC UPS and NIC ,
How to control ups output without web?
like send packet or Call Api Requests
  • Home & Office - UPS & Software
Kirk
Posted: ‎2024-10-11 11:29 AM
You may consider reading this document to get you started:
https://iportal2.schneider-electric.com/Contents/docs/UPS-PMAR-9LLM9N_R1_EN.PDF
RyanG32
Ensign RyanG32 Ensign
Ensign
Posted: ‎2024-10-13 06:59 AM
You can do this via SNMP thru that APC network management card if you are using APC Smartups with a network card.
Here is the link for the cards
AP9641  SNMP card with Dry contact
https://www.apc.com/us/en/product/AP9641/device-monitoring-and-management-network-management-cards-n...
Basic SNMP Card AP9640
https://www.apc.com/us/en/product/AP9640/device-monitoring-and-management-network-management-cards-n...
This cards use your local area network you can assign an IP on the card where you can access its web interface via local  http /https protocol or access the console via telnet / ssh or serial connection using hyper terminal  you also have other ways to monitor it by  SNMP Bacnet and Modbus TCP and Physical modbus( only on the AP9643 card.)
Another option is thru Powerchute serial shutdown software may work with back ups and Smartups unit that has a data port but you need the UPS to be always connected to a computer and you can use the software to use SNMP to command and monitor the UPS(I Personally have not tried it yet) it supports SNMPV1 and SNMPV3
See Page 22 - 28 of the user guide.
https://download.schneider-electric.com/files?p_Doc_Ref=SPD_CCON-PCSSUG_TypeB_EN&p_enDocType=User+gu...
The oid usually with write settings can be used to change configuration and issue commands
Hope this helps
