Posted: 2021-06-28 07:22 PM . Last Modified: 2024-03-26 02:33 AM
I have a APC UPS unit that is clicking on and off very rapidly, causing power to be cut on and off. Gosh, I hope it didn't damage my computer. This is a mission critical UPS unit that also powers my router and cable modem. I manually switched the UPS off and reconnected my components to another UPS unit. Is this UPS unit damaged?
Message was edited by: tomstevens55
Posted: 2021-06-28 07:23 PM . Last Modified: 2024-03-26 02:32 AM
I think the problem is due to low line voltage for example 190 - 205 V range for nominal line supply voltage of 220 V
It may be either due to some heavy power absorbing devices like electric motor,welding machine,cutter,laser printer etc either by you or someone in your locality.
Best way to avoid frequent on/off of ups unit you should lower the line voltage say 170 V range using a semi automatic voltage stabilizer so that ups can provide AVR boost to 230 V +/- 10% from 150 V ~ 190 V range, so the ups unit will not toggle frequently as 230 +/- 10% is an acceptable line fluctuation.
If you still have problem then use an online ups or some constant voltage transformer or servo stabilizer which can correct line fluctuation under +/- 1%.
Posted: 2021-06-28 07:22 PM . Last Modified: 2024-03-26 02:32 AM
If you have a laser printer on the same circuit(in control of the same circuit breaker/fse) as rest of the computer equipment, what you described often happens. Many laser printers draws power in pulses causing notches in line voltage. Put the laser printer on a separate circuit even if you have to run an extension cord.
Message was edited by: KVAr
Dirtfoot wrote...
What BackUPS model are you using? Some have the ability to adjust sensitivity through the front display.
