Cannot INSTALL PowerChute 3.0.2 on Windows 7
  • Cannot INSTALL PowerChute 3.0.2 on Windows 7
2151
Spock Teken
104
83
Posted: ‎2021-06-29 07:34 PM . Last Modified: ‎2024-03-21 02:47 AM
1614
Not to be confused with this thread, I guess --
https://community.exchange.se.com/t5/Datacenter-Forum/bd-p/datacenter-forum
Can't get the program to install on new Windows 7 machine, no previous installs.
I get to the "Destination Folder" step, push "Next", nothing happens.
I've seen the "error code 2738" before when I was unable to uninstall a different program on this machine.
I get no error messages with this install, it just won't go to the next step.
Posted: ‎2021-06-29 07:34 PM . Last Modified: ‎2024-03-21 02:46 AM
Seems to be a system issue. I found this post on the Microsoft forum that may help.
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_programs/error-2753-preventing-un...
I recommend running MS Fixit first and if that does not resolve the issue reregister the MSI installer as described in the Microsoft forum post.
Replies 11
here are a few items to try:
•can you please do the following and post the log file? if you don't want to post it, let me know and i'll arrange for you to send it to me.
1. Trigger the installation process by executing (double clicking) PCPE_Setup.exe
2. Go to c:\users\
3. Copy the PCPE_3.0.msi file to the desktop
4. Open a command prompt as administrator
5. Change directory to desktop
6. Run the command
msiexec /i PCPE_3.0.msi /l*vx install.txt (letter l then *vx)
7. The installer UI will be launched again
8. Run the normal installation steps
9. Send us the log file "install.txt" for analysis that is created.
• Check if Windows Script host engine is not registered to the OS. to fix this issue run the command wscript -regserver
(For info on Windows script host see http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wsh_overview.mspx?mfr...)
• If the above fails then try registering the Scripting run time dll using the command regsvr32 c:\Windows\System32\scrrun,dll
Head spinning.
Here's a link to txt file and screen cap of Windows Installer after getting through command prompt stuff (2 files) --
https://www.dropbox.com/sh/1lu49ohkr1hm91k/ra9Lsz--lD
The last resort stuff seemed to produce nothing as best I could tell.
Thanks so far, only so literate here.
Please explain --
"5. Change directory to desktop"
Something I'm doing in the command prompt?
yes, you'll need to do something like "cd c:\users\bob\Desktop"
i find it easiest if you open up windows explorer and type cd then just drag and drop your desktop folder icon into the prompt window and it will type the path out for you.
this may help http://dosprompt.info/
unfortunately those did not really help much. it really seems like the same issue outlined here: https://community.exchange.se.com/t5/Datacenter-Forum/bd-p/datacenter-forum
Thanks! New Dell here and I'd uninstalled McAfee early on. Will try the removal tool and report back.
Yes, the McAfee MCPR.exe did the trick. In fact, it solved another couple problems I had with uninstalls of other programs.
I got farther into the PowerChute install but now have a new problem. One dialog box says --
"The installer is unable to locate the battery backup connected to your computer. In order disable native power management, an American Power Conversion battery backup needs to be attached. If native power management is not disabled you may receive messages from Windows relating to 'battery'."
The next dialog box --
"Please check the USB connectivity between your PC and UPS before you proceed."
I have a BACK-UPS ES 550 am unaware of any USB connection. Am I missing something?
On your UPS there should be a port that says Data Port, this is where you are going to connect the USB cable that came with the UPS. One end goes to the UPS and the other end goes to an unused USB port of your computer.
Thanks JonPro. Changing from old pc to new, I'd forgotten the switch over the USB connection. Crawling into the dark corner and looking for a USB connection on the UPS was not clever.
So, up and running here, all is good. Thanks for all the time and help!
Windows 7 64 bit. I can never get the installation correct. Now i try to run an install and the gui only gives the "remove" option. When I select that I get an error 2753. Here is my install txt file:
=== Verbose logging started: 9/15/2015 19:02:05 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Windows\SYSTEM32\msiexec.exe ===
MSI (c) (1C:04) [19:02:05:911]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (1C:20) [19:02:05:927]: Resetting cached policy values
MSI (c) (1C:20) [19:02:05:927]: Machine policy value 'Debug' is 0
MSI (c) (1C:20) [19:02:05:927]: ******* RunEngine:
******* Product: PCPE_3.0.1.msi
******* Action:
******* CommandLine: **********
MSI (c) (1C:20) [19:02:05:927]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (1C:20) [19:02:05:943]: Cloaking enabled.
MSI (c) (1C:20) [19:02:05:943]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (1C:20) [19:02:05:943]: End dialog not enabled
MSI (c) (1C:20) [19:02:05:943]: Original package ==> C:\apc_try\PCPE_3.0.1.msi
MSI (c) (1C:20) [19:02:05:943]: Package we're running from ==> C:\Windows\Installer\306c6.msi
MSI (c) (1C:20) [19:02:05:943]: APPCOMPAT: Uninstall Flags override found.
MSI (c) (1C:20) [19:02:05:943]: APPCOMPAT: Uninstall VersionNT override found.
MSI (c) (1C:20) [19:02:05:943]: APPCOMPAT: Uninstall ServicePackLevel override found.
MSI (c) (1C:20) [19:02:05:943]: APPCOMPAT: looking for appcompat database entry with ProductCode '{8ED262EE-FC73-47A9-BB86-D92223246881}'.
MSI (c) (1C:20) [19:02:05:943]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (1C:20) [19:02:05:958]: MSCOREE not loaded loading copy from system32
MSI (c) (1C:20) [19:02:05:958]: Machine policy value 'DisablePatch' is 0
MSI (c) (1C:20) [19:02:05:958]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (1C:20) [19:02:05:958]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (1C:20) [19:02:05:958]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (1C:20) [19:02:05:958]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (c) (1C:20) [19:02:05:958]: APPCOMPAT: looking for appcompat database entry with ProductCode '{8ED262EE-FC73-47A9-BB86-D92223246881}'.
MSI (c) (1C:20) [19:02:05:958]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (1C:20) [19:02:05:958]: Transforms are not secure.
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\apc_try\install.txt'.
MSI (c) (1C:20) [19:02:05:958]: Command Line: CURRENTDIRECTORY=C:\apc_try CLIENTUILEVEL=0 CLIENTPROCESSID=2332
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{9CE177F0-380B-4EC5-83FC-9540EC9D0187}'.
MSI (c) (1C:20) [19:02:05:958]: Product Code passed to Engine.Initialize: '{8ED262EE-FC73-47A9-BB86-D92223246881}'
MSI (c) (1C:20) [19:02:05:958]: Product Code from property table before transforms: '{8ED262EE-FC73-47A9-BB86-D92223246881}'
MSI (c) (1C:20) [19:02:05:958]: Product Code from property table after transforms: '{8ED262EE-FC73-47A9-BB86-D92223246881}'
MSI (c) (1C:20) [19:02:05:958]: Product registered: entering maintenance mode
MSI (c) (1C:20) [19:02:05:958]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'.
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (c) (1C:20) [19:02:05:958]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI (c) (1C:20) [19:02:05:958]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (1C:20) [19:02:05:958]: Specifed source is not already in a list.
MSI (c) (1C:20) [19:02:05:958]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (1C:20) [19:02:05:958]: Machine policy value 'DisableBrowse' is 0
MSI (c) (1C:20) [19:02:05:958]: Machine policy value 'AllowLockdownBrowse' is 0
MSI (c) (1C:20) [19:02:05:958]: Adding new sources is allowed.
MSI (c) (1C:20) [19:02:05:958]: Package name retrieved from configuration data: 'PCPE_3.0.1.msi'
MSI (c) (1C:20) [19:02:05:958]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (1C:20) [19:02:05:958]: Machine policy value 'DisableMsi' is 0
MSI (c) (1C:20) [19:02:05:958]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (1C:20) [19:02:05:958]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (1C:20) [19:02:05:958]: Product {8ED262EE-FC73-47A9-BB86-D92223246881} is admin assigned: LocalSystem owns the publish key.
MSI (c) (1C:20) [19:02:05:958]: Product {8ED262EE-FC73-47A9-BB86-D92223246881} is managed.
MSI (c) (1C:20) [19:02:05:958]: Running product '{8ED262EE-FC73-47A9-BB86-D92223246881}' with elevated privileges: Product is assigned.
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\apc_try'.
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '2332'.
MSI (c) (1C:20) [19:02:05:958]: TRANSFORMS property is now:
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
MSI (c) (1C:20) [19:02:05:958]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '100'.
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Roaming
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\Favorites
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\Documents
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Local
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\Pictures
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Users\His\Desktop
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (1C:20) [19:02:05:958]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (c) (1C:20) [19:02:05:958]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (1C:20) [19:02:05:974]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (1C:20) [19:02:05:974]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (1C:20) [19:02:05:974]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'His'.
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding Installed property. Its value is '00:00:00'.
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\306c6.msi'.
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\apc_try\PCPE_3.0.1.msi'.
MSI (c) (1C:20) [19:02:05:974]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (1C:04) [19:02:05:974]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 9/15/2015 19:02:05 ===
MSI (c) (1C:20) [19:02:05:974]: Note: 1: 2205 2: 3: PatchPackage
MSI (c) (1C:20) [19:02:05:974]: Machine policy value 'DisableRollback' is 0
MSI (c) (1C:20) [19:02:05:974]: User policy value 'DisableRollback' is 0
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (1C:20) [19:02:05:974]: Doing action: INSTALL
Action 19:02:05: INSTALL.
Action start 19:02:05: INSTALL.
MSI (c) (1C:20) [19:02:05:974]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (1C:20) [19:02:05:974]: Running UISequence
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (1C:20) [19:02:05:974]: Doing action: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
Action 19:02:05: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action start 19:02:05: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
MSI (c) (1C:20) [19:02:05:974]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E'
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\'.
Action ended 19:02:05: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
MSI (c) (1C:20) [19:02:05:974]: Doing action: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
Action 19:02:05: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action start 19:02:05: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
MSI (c) (1C:20) [19:02:05:974]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E'
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\SysWOW64\'.
Action ended 19:02:05: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
MSI (c) (1C:20) [19:02:05:974]: Doing action: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
Action 19:02:05: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action start 19:02:05: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
MSI (c) (1C:20) [19:02:05:974]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E'
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\'.
Action ended 19:02:05: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
MSI (c) (1C:20) [19:02:05:974]: Doing action: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
Action 19:02:05: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action start 19:02:05: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
MSI (c) (1C:20) [19:02:05:974]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E'
MSI (c) (1C:20) [19:02:05:974]: PROPERTY CHANGE: Adding SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\SysWOW64\'.
Action ended 19:02:05: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
MSI (c) (1C:20) [19:02:05:974]: Doing action: PrepareDlg
Action 19:02:05: PrepareDlg.
Action start 19:02:05: PrepareDlg.
MSI (c) (1C:20) [19:02:05:974]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'PrepareDlg'
Info 2898. For WixUI_Font_Normal textstyle, the system created a 'Tahoma' font, in 0 character set, of 13 pixels height.
Info 2898. For WixUI_Font_Bigger textstyle, the system created a 'Tahoma' font, in 0 character set, of 19 pixels height.
Action 19:02:05: PrepareDlg. Dialog created
Action ended 19:02:05: PrepareDlg. Return value 1.
MSI (c) (1C:20) [19:02:05:989]: Doing action: SetProductshortName
Action 19:02:05: SetProductshortName.
Action start 19:02:05: SetProductshortName.
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetProductshortName'
Action ended 19:02:05: SetProductshortName. Return value 1.
MSI (c) (1C:20) [19:02:05:989]: Doing action: AppSearch
Action 19:02:05: AppSearch. Searching for installed applications
Action start 19:02:05: AppSearch.
AppSearch: Property: HIBERNATIONKEY, Signature: CheckAPCReg
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\APC\PowerChute Personal Edition\3.02.00\Settings 3: 2
AppSearch: Property: INSTALLDIR, Signature: Locate_22InstallDir
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\APC\APC PowerChute Personal Edition\2.02.00 3: 2
AppSearch: Property: INSTALLDIR, Signature: Locate_30InstallDir
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\APC\APC PowerChute Personal Edition\3.00.00 3: 2
AppSearch: Property: INSTALLDIR, Signature: Locate_3001InstallDir
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\APC\PowerChute Personal Edition\3.01.00 3: 2
AppSearch: Property: BROWSER, Signature: DefaultBrowser
MSI (c) (1C:20) [19:02:05:989]: WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\Internet Explorer\IEXPLORE.EXE' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0).
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding BROWSER property. Its value is 'C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE'.
AppSearch: Property: PCPEFOUND211, Signature: PCPERegistry
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\APC\APC PowerChute Personal Edition\2.01.100 3: 2
AppSearch: Property: PCPEFOUND21, Signature: RegPCPE21Search
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\APC\APC PowerChute Personal Edition\2.01.000 3: 2
AppSearch: Property: PCPEFOUND22, Signature: RegPCPE22Search
AppSearch: Property: PCPEFOUND30, Signature: RegPCPE30Search
AppSearch: Property: PCPEFOUND3001, Signature: RegPCPE3001Search
Action ended 19:02:05: AppSearch. Return value 1.
MSI (c) (1C:20) [19:02:05:989]: Doing action: FindRelatedProducts
Action 19:02:05: FindRelatedProducts. Searching for related applications
Action start 19:02:05: FindRelatedProducts.
MSI (c) (1C:20) [19:02:05:989]: Skipping FindRelatedProducts action: not run in maintenance mode
Action ended 19:02:05: FindRelatedProducts. Return value 0.
MSI (c) (1C:20) [19:02:05:989]: Skipping action: AlreadyUpdated (condition is false)
MSI (c) (1C:20) [19:02:05:989]: Skipping action: ExitOnRepair (condition is false)
MSI (c) (1C:20) [19:02:05:989]: Doing action: LaunchConditions
Action 19:02:05: LaunchConditions. Evaluating launch conditions
Action start 19:02:05: LaunchConditions.
Action ended 19:02:05: LaunchConditions. Return value 1.
MSI (c) (1C:20) [19:02:05:989]: Doing action: ValidateProductID
Action 19:02:05: ValidateProductID.
Action start 19:02:05: ValidateProductID.
Action ended 19:02:05: ValidateProductID. Return value 1.
MSI (c) (1C:20) [19:02:05:989]: Doing action: CostInitialize
Action 19:02:05: CostInitialize. Computing space requirements
Action start 19:02:05: CostInitialize.
MSI (c) (1C:20) [19:02:05:989]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (c) (1C:20) [19:02:05:989]: Baseline: Sorting baselines for {8ED262EE-FC73-47A9-BB86-D92223246881}.
MSI (c) (1C:20) [19:02:05:989]: Baseline: New baseline 3.0.2 from transaction.
MSI (c) (1C:20) [19:02:05:989]: Baseline: Sorted order Native: Order 0.
MSI (c) (1C:20) [19:02:05:989]: Baseline Data Table:
MSI (c) (1C:20) [19:02:05:989]: ProductCode: {8ED262EE-FC73-47A9-BB86-D92223246881} Version: 3.0.2 Attributes: 4 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (c) (1C:20) [19:02:05:989]: Baseline File Table:
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
Action ended 19:02:05: CostInitialize. Return value 1.
MSI (c) (1C:20) [19:02:05:989]: Doing action: FileCost
Action 19:02:05: FileCost. Computing space requirements
Action start 19:02:05: FileCost.
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 2205 2: 3: Class
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 2205 2: 3: Extension
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 2205 2: 3: TypeLib
Action ended 19:02:05: FileCost. Return value 1.
MSI (c) (1C:20) [19:02:05:989]: Doing action: CostFinalize
Action 19:02:05: CostFinalize. Computing space requirements
Action start 19:02:05: CostFinalize.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 2205 2: 3: Patch
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding APCDIR property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\APC\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding APC property. Its value is 'C:\Program Files (x86)\APC\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.762.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_af164407\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_ac24e7bf\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_ac1be589\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_ac1be588\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_ac1be586\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_ac1be585\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51e92916\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51e92915\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51e92914\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51e92913\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51e92912\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51e92910\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51e828d7\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51e92911\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_af164407\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51e427d4\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Manifests\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.762.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_9193a620671dde41\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.762.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.762.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\Manifests\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E property. Its value is 'C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_10b2f55f9bffb8f8\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding es property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\es\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding ru property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\ru\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding pt property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\pt\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding ja property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\ja\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding it property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\it\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding de property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\de\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding fr property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\fr\'.
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding zh_CHS property. Its value is 'C:\Program Files (x86)\APC\PowerChute Personal Edition\zh-CHS\'.
MSI (c) (1C:20) [19:02:05:989]: Target path resolution complete. Dumping Directory table...
MSI (c) (1C:20) [19:02:05:989]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: TARGETDIR , Object: E:\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: StartMenuFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: ProgramMenuFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: APCDIR , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\APC\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: StartupFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: ProgramFilesFolder , Object: C:\Program Files (x86)\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: APC , Object: C:\Program Files (x86)\APC\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: INSTALLDIR , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\SysWOW64\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.762.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_af164407\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_ac24e7bf\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_ac1be589\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_ac1be588\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_ac1be586\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_ac1be585\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51e92916\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51e92915\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51e92914\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51e92913\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51e92912\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51e92910\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51e828d7\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51e92911\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_af164407\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51e427d4\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Manifests\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.762.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_9193a620671dde41\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\SysWOW64\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.762.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.762.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\Manifests\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E , Object: C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_10b2f55f9bffb8f8\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: es , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\es\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: ru , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\ru\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: pt , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\pt\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: ja , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\ja\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: it , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\it\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: de , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\de\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: fr , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\fr\
MSI (c) (1C:20) [19:02:05:989]: Dir (target): Key: zh_CHS , Object: C:\Program Files (x86)\APC\PowerChute Personal Edition\zh-CHS\
MSI (c) (1C:20) [19:02:05:989]: PROPERTY CHANGE: Adding INSTALLLEVEL property. Its value is '1'.
Action ended 19:02:05: CostFinalize. Return value 1.
MSI (c) (1C:20) [19:02:05:989]: Doing action: MigrateFeatureStates
Action 19:02:05: MigrateFeatureStates. Migrating feature states from related applications
Action start 19:02:05: MigrateFeatureStates.
MSI (c) (1C:20) [19:02:05:989]: Skipping MigrateFeatureStates action: not run in maintenance mode
Action ended 19:02:05: MigrateFeatureStates. Return value 0.
MSI (c) (1C:20) [19:02:05:989]: Skipping action: UpgradeDlg (condition is false)
MSI (c) (1C:20) [19:02:05:989]: Skipping action: WelcomeDlg (condition is false)
MSI (c) (1C:20) [19:02:05:989]: Skipping action: LicenseAgreementDlg (condition is false)
MSI (c) (1C:20) [19:02:05:989]: Doing action: MaintenanceWelcomeDlg
Action 19:02:05: MaintenanceWelcomeDlg.
Action start 19:02:05: MaintenanceWelcomeDlg.
MSI (c) (1C:20) [19:02:05:989]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'MaintenanceWelcomeDlg'
  • PowerChute
