Can frequency change 50HZ To 60 Hz
  • Can frequency change 50HZ To 60 Hz
2151
123
Posted: ‎2021-06-29 08:25 AM . Last Modified: ‎2024-03-21 04:16 AM
3076
Hi
can change frequency 50hz to 60hz.but input and output voltage remain 110v.
in generally
Replies 9
3076
could you please specify any part numbers in use?
then i'd say no. international SKUs for Smart UPS RT will do frequency conversion but do not do 110/120v.
in generally
Reuser
Crewman Reuser
Crewman
Posted: ‎2024-10-28 07:57 AM
In response to BillP
1807
Hello there,
I am a new comer here seeking helps. I am using an APC Back-UPS BP1400 as an emergency power supply at home, which uses solar panel to charge its battery so that it's not plugged in the house line socket, and I only turn it on whenever I need to, and it only operates in battery mode. But it can run as a normal UPS when connected to both the line power supply(120V 60Hz here) and the battery, I used it that way before. However, recently I found that its output power is of 50Hz instead of 60Hz(which it might be locked to from previous usage). Is there any way to change this on-battery output frequency?
  • shifangming@hotmail.com
Kirk
Posted: ‎2024-10-29 05:13 AM
In response to Reuser
1805
How do you know the system is at 50 Hz now?!? 🤔
Reuser
Crewman Reuser
Crewman
Posted: ‎2024-10-29 09:11 AM
In response to Teken
I use scope to know.
Reuser
Crewman Reuser
Crewman
Posted: ‎2024-10-30 06:21 AM
1753
Hi, I used an oscilloscope to view the output waveform.
Actually I replied to you yesterday by clicking “Reply” button and wrote a message then clicked “Reply” button again to send it. But I don’t see my reply posted following your message.
Kirk
Posted: ‎2024-11-04 04:54 AM
1752
At a high level this is how the system operates.
Upon applied power (voltage & frequency) is determined and fixed to this input source.
If your location is 120 VAC @60 Hz simply plug the system into an outlet.
Reuser
Crewman Reuser
Crewman
Posted: ‎2024-11-05 04:11 AM
Thank you, I will try accordingly and let you know the results.
