Battery connector correctly connected?
  • Battery connector correctly connected?
2150
127
Back-UPS
TomPouceOnline
Ensign TomPouceOnline
Ensign
Posted: ‎2022-10-28 06:49 AM
14
25270
Hi
I got a new BX750MI Back-UPS.
1) According to the attached picture, is the yellow battery connector enough pushed? I can start the UPS but I would like to avoid any battery disconnection because of bad contact.
2) If I need to disconnect the battery, do I just need to pull the connector strongly?
Thanks in davance for your feedback.
  • Home & Office - UPS & Software
  • battery connector
JonPro
Commander JonPro Commander
Commander
Posted: ‎2022-11-17 06:58 PM
In response to TomPouceOnline
24943
Hi @TomPouceOnline
Apologies for the delay in my response, I have checked with our UPS Experts and was advised that if it doesn't get fully inserted we just need to make sure that it makes contact to close the circuit.
Replies 14
JonPro
Commander
Posted: ‎2022-11-03 10:43 PM
25182
Hi @TomPouceOnline
Thank you for reaching out to the SE Community, my name is Jon and I will assist you with this query.
I strongly suggest that you try to push it in more.  The metal shouldn't be exposed and the yellow plastic should seal it.
TomPouceOnline
Ensign
Posted: ‎2022-11-06 04:17 AM
In response to JonPro
Hi @JonPro
Thanks a lot for your feedback. I tried to push more but it seems it is not possible. Do you have a picture of this battery connector type correctly sealed in?
Regards
Abdullah07
Crewman Abdullah07
Crewman
Posted: ‎2022-11-06 06:31 AM
Hi @TomPouceOnline
My Name is Abdullah. If You want to pull out you need to tester or straight screw 🪛 and full with it.
Abdullah07
Crewman Abdullah07
Crewman
Posted: ‎2022-11-06 06:37 AM
25153
@TomPouceOnline
Hi I see in picture your battery connector perfectly fitted. I think Your battery is dead need to replace
Tell me about duration of Purchase or UPS usage for more details
  • battery
  • replacement
TomPouceOnline
Ensign
Posted: ‎2022-11-07 12:58 AM
In response to Abdullah07
6
25129
Hi @Abdullah07
Why do you say the battery is dead? The UPS is new. My only concern is about the battery connector type which is different from my former BX700UI. With the old model the connector was completely pushed into the UPS body. This doesn't look the same with the new connector type on the BX750MI (do you confirm @JonPro ?).
Regards
JonPro
Commander
Posted: ‎2022-11-07 04:11 AM
25116
@TomPouceOnline
I found a video on how UPSs that use this kind of battery connector is being used.  You can skip to the 0.10 seconds mark of the video.
TomPouceOnline
Ensign
Posted: ‎2022-11-07 10:55 AM
25097
Hi @JonPro
Thanks for the video. However this is the old connector type (like for the BX700UI). For the BX750MI the connector is different.
Regards
Thomas
JonPro
Commander
Posted: ‎2022-11-07 05:39 PM
Let me check on this further.  By any chance, have you raised a case with our Technical Support team?
Abdullah07
Crewman Abdullah07
Crewman
Posted: ‎2022-11-07 06:00 PM
Yeah in picture battery connector connected correctly.
JonPro
Commander
24944
Hi @TomPouceOnline
TomPouceOnline
Ensign
Posted: ‎2022-11-18 09:56 AM
Hi @JonPro
Thanks a lot for your valuable feedback.
With best regards
fosiqqqq
fosiqqqq
Cadet
Posted: ‎2024-05-14 03:34 AM
16235
So I have the same problem and I still don't know if I should try to push it more or it should stay like in the picture from first post?
koby100
koby100
Cadet
Posted: ‎2024-05-15 07:51 AM
In response to fosiqqqq
I had the same Issue. The yellow battery connector does not get fully into the UPS.
I searched many posts about this issue and found out that it is OK.
Strange design, but the UPS works great.
mosp
mosp
Cadet
Posted: ‎2024-05-28 08:14 AM
Just got a new BX750MI-FR and I could not get push the connector all the way in. After 24hours of charging I connected a printer and the UPS started beeping. Removed the printer and tried to push in the connector further, this time I succeeded, but after connecting a rinter the beeping sounds came back. I have no windows laptop to install Powerchute. Is there another way to check the battery?
