Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Back ups xs 1400u battery stuck at 10% for the first time charging
  • Back ups xs 1400u battery stuck at 10% for the first time charging
2151
Spock Teken
109
83
Posted: ‎2021-06-28 07:20 AM . Last Modified: ‎2024-03-26 10:34 PM
1622
Hi I bought this ups yesterday I plugged in AC power and ups connected to server. Ups battery has been stuck at 10% and it has been 24 hours what  should I do ?
I did brain dead reset refer to website didn't change anything still stuck at 10% any ideas ? should I bring back ups ?
3VOtLkNqZCbXUvudffOlmg%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg3VOtLkNqZCbXUvudffOlmg%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg
CBN3CxVrgcOmaCtsS4xDaw%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpegCBN3CxVrgcOmaCtsS4xDaw%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg
3OBfFIzhoULRWlZBnETwVg%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg3OBfFIzhoULRWlZBnETwVg%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg
Posted: ‎2021-06-28 07:21 AM . Last Modified: ‎2024-03-26 10:34 PM
Thank you Matt.
Replies 5
Found solution I guess there is something wrong with business software I ended up install personal PowerChute and I can see battery is 100% full
Hi Lucas
Looking at the screen shots, the battery is fine and fully charged.  It seems to be a possible problem with Powerchute Business Edition as many of the values are 10% of the actual correct values (internal temperature, input/output frequency, input voltage, as well as the battery charge).
Can you tell use what version of Powerchute Business Edition you are running, that will help us get you the solution.
Matt
Hi Matt,
Business PowerChute 9.5.0.301
Ups Firmware version is     926.T2 .I / 01.01a (1201 - 19)
It is interesting that self safe unable to perform on personal version I successfully did self test on business version.
Thank you.
Hi Lucas
I've had it confirmed that the Back UPS XS isn't compatible with Business Edition just the Smart UPS models are.
Thank you Matt.
