Posted: ‎2024-11-01 09:59 AM
I bought a Back-UPS RS 900G , and connected my server to it.
For some reason, the APC is reporting only continiously usage load of 4% / 22 watt , which isnt correct as when Im doing load tests, the CPU and spinning HDD's make up to more wattage.
I connected a Tasmoto smart plug so that the connection is:
Server --> Smart plug --> APC
The smart plug reports peak usage of 200watt and goes up and down a lot based on the load, yet the APC reports only 4% / 22 wattage
Im reading this value diretly from the screen of the APC, not via any tools
What can it be?
Posted: ‎2024-11-01 02:24 PM
What does the APC Power Chute Software indicate while the server is running?!?
If you still have incandescent bulbs say 100 watts. Connect at least 100-300 watts and report back what the LCD indicates vs PCPE Software.
Only connect this resistive load while you test! 👍
