Back-UPS Pro BR1000G Beeps At Regular Intervals
  • Back-UPS Pro BR1000G Beeps At Regular Intervals
2151
118
83
WKym
WKym
Cadet
Posted: ‎2025-02-19 08:42 AM
343
My UPS beeps every 5 minutes or so, with no apparent error or issue.  When I read this document:
APC Back-UPS Pro®
1000/1100/1400
User’s Manual
990-2012E Revision 6 2/02
It states this:
UPS beeps occasionally. Normal UPS operation. None. The UPS is protecting the load.
However, when I read this document:
EN 990-3804B
10/2014
There is no mention of an occasional beep.
Which is correct?
Thanks, Kym.
  • Home & Office - UPS & Software
Kirk
Posted: ‎2025-02-20 05:58 AM
327
If the system is connected to a computer running APC Power Chute software. You will be able to see the active fault / error codes.
Please relay the data, event, ups logs here for review. Based on your description it sounds like the system was in AVR / Battery Mode.
The LCD would indicate the same if either mode was active. Lastly, manually initiate a Self Test and report back the results.
Questions Ask . . . 👍
WKym
WKym
Cadet
Posted: ‎2025-02-23 09:54 PM
In response to Teken
Thanks for the feedback.
I do not have Power Chute installed.
I initiated a self test (holding down power button for about 6 seconds) and no issue was indicated (all of the LCD display information looked normal to me).
When running, the device shows normal operation, does not indicate on battery mode.
I reset the event counter and will monitor to see if I can correlate any event to the regular beeping noise.
