We Value Your Feedback!
Back-UPS Pro 900 AVR and Error Light Flashing
  • Re: Back-UPS Pro 900 AVR and Error Light Flashing
2151
Teken
Spock Teken
100
83
Anonymous user
Not applicable
Posted: ‎2021-06-28 06:48 PM . Last Modified: ‎2024-03-26 02:55 AM
2488
My Back-UPS Pro 900 UPS is indicating an error which I cannot identify from any manual. The AVR indicator on the LCD is flashing together with the System Fault indicator. The UPS also then beeps 3 times every minute. No fault code is shown on the LCD display. When the AVR indicator is flashing, the indicator for low or high input power does not show.
When powered on all the systems checks are completed without error. About a minute after system checks are completed the above error starts showing up.
Input power is fine, and batteries have been replaced recently.
Any help will be appreciated.
  • Back-UPS & Surge Protectors
  • avr
  • beeping
  • fault
  • flashing
  • system
Anonymous user
Not applicable
On 2/11/2021 12:33 PM, Nick said:
When powered on all the systems checks are completed without error. About a minute after system checks are completed the above error starts showing up MyLowesLife.
Over temperature On Battery - UPS has exceeded the over temperature threshold. Note: The UPS will beep and the red LED will illuminate till the internal temperature reaches the normal range for 5 minutes before the UPS shuts down.
Replies 2
Anonymous user
Not applicable
knopfler19_apc
Crewman knopfler19_apc
Posted: ‎2024-01-09 07:15 PM
Same happened today with a “new” replacement unit. Is it correct that the cause is over-heating? Is the unit defective? At 25ºC the battery should not overheat without being working (I have had many apc in south Spain with A LOT higher ambient temp with no problems at all)
This is a heading
