Back-UPS CS 500 not waking up after configuring WAKEUP parameter
  • Back-UPS CS 500 not waking up after configuring WAKEUP parameter
2150
127
Posted: ‎2021-06-28 08:13 AM . Last Modified: ‎2024-03-26 03:34 AM
I have a Back-UPS CS 500 connected with a usb cable to a raspbian buster machine.
I think configuration wise it should work as i get a status result for "sudo apcaccess status":
APC : 001,045,1050
DATE : 2019-10-24 18:41:37 +0200
HOSTNAME : LIEVITATORE01
VERSION : 3.14.14 (31 May 2016) debian
UPSNAME : L-01
CABLE : USB Cable
DRIVER : USB UPS Driver
UPSMODE : Stand Alone
STARTTIME: 2019-10-24 18:41:34 +0200
MODEL : Back-UPS CS 500
STATUS : ONLINE
LINEV : 232.0 Volts
LOADPCT : 5.0 Percent
BCHARGE : 84.0 Percent
TIMELEFT : 44.6 Minutes
MBATTCHG : 90 Percent
MINTIMEL : 10 Minutes
MAXTIME : 60 Seconds
OUTPUTV : 230.0 Volts
SENSE : Medium
DWAKE : 0 Seconds
DSHUTD : 0 Seconds
LOTRANS : 180.0 Volts
HITRANS : 266.0 Volts
RETPCT : 0.0 Percent
ITEMP : 29.2 C
ALARMDEL : No alarm
BATTV : 13.4 Volts
LINEFREQ : 50.0 Hz
LASTXFER : No transfers since turnon
NUMXFERS : 0
TONBATT : 0 Seconds
CUMONBATT: 0 Seconds
XOFFBATT : N/A
SELFTEST : NO
STESTI : None
STATFLAG : 0x05000008
MANDATE : 2008-08-01
SERIALNO : 4B0831P17685
BATTDATE : 2008-08-01
NOMOUTV : 230 Volts
NOMINV : 230 Volts
NOMBATTV : 12.0 Volts
NOMPOWER : 300 Watts
FIRMWARE : 808.q8.I USB FW:q8
END APC : 2019-10-24 18:41:37 +0200
what is really annoying is the fact that no matter which parameter i set in apcupsd.conf as WAKEUP parameter or SLEEP i see no changes in DWAKE nor DSHUTD parameters.
it is like that the configuration takes no real effect.
My goal is to make sure that after 060 seconds main power is back the UPS will turn on automatically.
Some details:
apcupsd 3.14.14 (31 May 2016) debian
apcupsd.conf
UPSNAME L-01
UPSCABLE usb
UPSTYPE usb
DEVICE
LOCKFILE /var/lock
SCRIPTDIR /etc/apcupsd
PWRFAILDIR /etc/apcupsd
NOLOGINDIR /etc
ONBATTERYDELAY 6
BATTERYLEVEL 90
MINUTES 10
TIMEOUT 60
ANNOY 300
ANNOYDELAY 60
NOLOGON disable
KILLDELAY 0
NETSERVER on
NISIP 127.0.0.1
NISPORT 3551
EVENTSFILE /var/log/apcupsd.events
EVENTSFILEMAX 10
UPSCLASS standalone
UPSMODE disable
STATTIME 0
STATFILE /var/log/apcupsd.status
LOGSTATS off
DATATIME 0
WAKEUP 060
SLEEP 180
the command "sudo apcupsd --power-off" works well but the ups is not waking up after main power comes back. i remember it was in the past but for some reason is no longer.... any help?
Best regards
Replies 0
