Posted: 2021-06-28 08:15 AM . Last Modified: 2024-03-26 03:32 AM
Hi, I have a Back-UPS 550 model BE550G-LM (4B1710P12448).
A couple of days ago a constant audible tone turned on and it wont shut off. The battery back up doesn't work neither with the APC turned on nor off. When I turn it on, a green light beeps for a couple of seconds in silence, but after that an alternating red/green light flashes along with the constant tone.
The tone and the alternating red/green flashes occur whether I'm using 1 of the 8 plugs or none.
According to the User Manual Back-UPS BE550G/BE700G I might need a Battery Replacement but I don't think we got the Back-UPS that long ago.
Two questions:
1.- I think we are eligible for warranty replacement, If you think we are, what should we do? who do we contact?...
2.- By having turned off the Back-UPS the tone goes off meaning that only 4 of the 8 plugs work. But i normally have 6 plugs in use. Is there a way to still be able to use the 8 plugs without the constant tone on?
Thanx for your time. Pablo
Sorry for the inconvenience. You should contact local support for asistance. Local support contact information will be found at this link. https://www.apc.com/us/en/support/contact-us/index.jsp
You may need to change the location in the upper left of the web page.
