BX700U
  • BX700U
2150
125
Posted: ‎2021-06-28 08:29 AM . Last Modified: ‎2024-03-26 03:23 AM
1070
BX700U
I recently purchased a BX700U and all was well until I went on holiday!  Before leaving I turned everything off but now my PC refuses to recognize the UPS.  I have tried all the obvious things, such as removing all other USB devices, un-installing and re-installing Powerchute (it won't of course as it can't see the UPS),  a new USB lead, another USB socket.  Any suggestions gratefully received.
  • bx700
  • usb
Thanks very much for your speedy assistance.  All is sorted now, thanks again.
Marc
  • bx700u
  • usb
You should verify that the APC USB driver is enabled. See Schneider Electric FAQ FA310907. If the driver is correct try to reset the UPS.
To reset
1: Disconnect any attached load.
2: Unplug the UPS from the wall socket.
3: Disconnect the UPS' internal battery.
4: Push and hold the "On" button on the UPS for 5 seconds
5: Reconnect internal battery.
6: Plug UPS in to known good power source.
7: Turn UPS on.
Marc
  • bx700u
  • usb
