BR600CI-IN
  • BR600CI-IN
2151
120
upsat_R
upsat_R
Cadet
Posted: ‎2024-10-30 04:55 AM
348
BR600CI-IN
As my UPS was not charging the battery I opened it. Found one 7 pin IC marked on the PCB as IC7 damaged and hence can't find the number. Can someone help me with the IC number? All other components seems to be OK.
  • Home & Office - UPS & Software
KarimEissa
Commander KarimEissa Commander
Commander
Posted: ‎2025-02-11 10:26 PM
HBN units including this model are not field repairable ,if a hardware malfunction appeared in the unit and it is confirmed by fault declaration then entire unit would need to be replaced ,you may contact your local CCC team to provide you  with alternatives such as directing you to local service centers for repair  or RMA the unit if it is under warranty or advise to purchase another unit as a modernization with extended warranty services
Karim
KarimEissa
Commander
Karim
