APC SMT 750i replace battery warning despite battery replacement - continued
  • APC SMT 750i replace battery warning despite battery replacement - continued
2150
127
rsdu
Crewman rsdu
Crewman
Posted: ‎2024-02-25 08:46 AM
1477
Hi there,
I have a APC SMT 750i with a bit of a history (https://community.se.com/t5/APC-UPS-for-Home-and-Office-Forum/APC-SMT-750i-replace-battery-warning-d...) and a rather new battery (see linked thread for details).
That setup worked quite well for about a month. Out of the sudden the "replace battery" warning showed up again. After a while ignoring the error (busy week, etc.) it turned into an "overload error" with a power off of all connected loads. Resetting the UPS and reinstalling the battery as a "new" one fixed the issue for the time being. Do I have a faulty unit?
Many thanks for any advice!
Marvin
  • Home & Office - UPS & Software
RyanG32
Ensign RyanG32 Ensign
Ensign
Posted: ‎2024-09-15 02:47 PM
The UPS usually detects sudden voltage drops on battery and trigger a replace battery warning and often times when there is not enough supply of voltage from the  battery the UPS may think that it is overloaded since it will pull too much amperage the UPS will protect itself by turning off the load instead.
I would suggest that you run a full calibration of the batteries to make sure that the UPS is calibrated on what is the actual capacity  and knows what to expect from the battery.
How do I perform a Battery Calibration on my Smart-UPS?
https://www.se.com/ph/en/faqs/FA284198/
There are also instances when a different battery is installed with a different battery chemistry and the voltage / charge percentage of the battery than what the UPS expects so make sure that you purchase genuine APC cartridges made for the unit and avoid refurbished battery packs.
Why should I use only genuine APC Replacement Battery Cartridge (RBC) in my APC UPS?
https://www.se.com/ph/en/faqs/FA328895/
You may also want to consider that the sensors and other UPS  components may also fail if the UPS is old.
You may want to look at this article as well to help you consider if  you need a new battery or a UPS
Single Phase UPS Basic Life Expectancy - When to consider a new unit over a battery.
https://www.se.com/us/en/faqs/FAQ000265093/
rsdu
Crewman rsdu
Crewman
Posted: ‎2024-09-22 11:53 AM
Hi Ryan,
Thanks for taking the time replying to my issue.
Unfortunately, I was already unable to calibrate the battery as indicated in my first issue (linked in my post).
In the meantime I replaced the unit with another used one, which had old batteries. I guess my unit was just faulty, I paid a lesson ...
