APC BACK-UPS 1400VA, 230V. RJ45 ports
  • APC BACK-UPS 1400VA, 230V. RJ45 ports
2151
120
Posted: ‎2021-06-28 08:41 AM . Last Modified: ‎2024-03-26 03:18 AM
3126
Hi guys,
I struggle to determine if this UPS can be connected to the LAN.
I've tried the 2 RJ45 ports and my switch doesn't show any led.
My aim was to use PowerChute Network to stop my devices once battery is running on low levels on a power cut.
Any help would be welcome.
Posted: ‎2021-06-28 08:41 AM . Last Modified: ‎2024-03-26 03:17 AM
Hi Flavia
The back ups range uses a USB serial connection directly into your pc to use the Powerchute application.
The two Rj45 ports you see are to protect your data lines from surges (your internet cat 5 cable from the outside world goes into the In port and another cat 5 cable goes from the out port into your router)
Regards
Matt
Replies 4
Hi
The RJ45 ports are for data line surge protection.
The Back UPS range can only use Powerchute Personal Edition via the USB port.
Regards
Matt
Hi Matt,
I try to understand your reply, as I have the same issue, but I'm not very knowledgeable in this type of devices, so I'm afraid I don't quite get your answer.
My idea was to channel my connection from the router to the back-ups to my computer. If I understand properly, this is not the way it works?
Thank you!
Best
flavia
Hi Flavia
Regards
Matt
Hi Matt,
Thank you! Now I understand!
Have a great day ahead.
best
flavia
