Posted: β2021-06-29 04:29 AM . Last Modified: β2024-03-22 12:39 AM
Hi!
i have cable USB-To-RS232 (940-0272A) at home, got it from friend, no UPS
I wonder if it has normal pinout or if pinout is different from normal RS-232 pinout?
i heard that APC's smart-signalling cables have data pins on 1 and 2?
Can anyone pop me up pinout pic so i can make pinout combo? I'd be really thankfull π
Thanks, bye
watts
Posted: β2021-06-29 04:30 AM . Last Modified: β2024-03-22 12:39 AM
Hi!
Thanks, bye
watts
these cables are proprietary and do have different pinouts. we cannot give the pinouts to the cables on here unfortunately since they are indeed proprietary.
Agh crap. Well what about tearing the 2nd half from PLchip to the COM site off and soldering our own connector? pinouts then sould be known! π
You might also want to check out this APC knowledgebase article: [computer interface port specifications |http://nam-en.apc.com/app/answers/detail/a_id/1481/kw/Computer%20Interface].
Thanks for link. What i stratched out:
so there we go... pin2 is TXD, pin1 is RXD... thats what i needed ^^ a bit of it. ---> but wth are 3, 5, 6 and 7 for? π
Pin 2 is TXD and pin 1 is RXD on the UPS side. Pin 7 of the UPS appears to be to turn the UPS on and off. As for 3, 5, and 6, I can't tell you anything more than what's in the knowledge base article.
So it seems that there's no way excempt of tearing out whole housing of a chip and re-soldering straight from it.
If i find anything, i'll let you know π
First: epic correction of 1st post: RS323, not 232, typo π
2nd: I've stripped cable and saw 3 wires. I'm gonna snap connector off and try multimeter for probing which pin is which, then i'd have idea what is what.
I'll solder on new connector and put it in housing... For mor infos about work-in-progress mail me (vatts[dot]linux[at]hotmail[dot]com)
Found proper wiring, and thing just works π There was a lot of experimenting, but at least now i have Me-Powered USB2RS 323 (!!) cable π
Hi!
Thanks, bye
watts
