425 continuous beep and red light
  • 425 continuous beep and red light
2150
125
jefferis
Crewman jefferis
Crewman
Posted: ‎2022-12-19 10:13 AM
2469
So, I read some solutions but my issue is slightly different.  I had a 1 sec power failure/surge.  The 425 started a long continuous beep with a red light.   I turned it off and  waited a few seconds but it kept flashing from green to red and beeping.  So I turned it off and unplugged all devices, waited a minute or 2 and then plugged in 2 into the surge protector and 1 less than before into the backup.  I turned it back on and the red light went away.      Any ideas what might be an issue.  The backup plugins do not have a huge power drain.  A modem, wifi antenna and backup NAS.
  • Home & Office - UPS & Software
jefferis
Crewman jefferis
Crewman
Posted: ‎2025-06-12 06:32 AM
In response to JonPro
I replaced the battery and it solved the issue.  BTW,  Schneider no longer asks for a recycled return.  I can't find any place that accepts used batteries 😞   This is a landfill problem
JonPro
Commander JonPro Commander
Commander
Posted: ‎2022-12-20 05:14 PM
2441
Hi @jefferis
Will you be able to share the exact model of the UPS and the wattage drawn by your load?  I am thinking that the device might be showing an overload condition or a hiccup.
Plug your load one at a time and each time you plug them, unplug the UPS from the wall outlet to see if you could replicate the issue.
jefferis
Crewman jefferis
Crewman
