3000RMI smart UPS
Select a Country
  • 3000RMI smart UPS
BillP Leader
2150
150
83
Posted: ‎2021-06-29 08:10 AM . Last Modified: ‎2024-03-21 04:19 AM
827
3000RMI smart UPS
Is it possible to use as a solar UPS without A/C input supply ( Only applying D/C 48 Volt to the UPS from Battery and battery connected through seperate solar charger from the solar panel)
Message was edited by: babumj
Sir,
Thank you for the reply, I have found one problem that we are not able to start the UPS only with 48Volt battery. First need A/C supply to initialize the UPS then disconnect A/C power UPS will remain continue, once switch off from the panel again requied A/C power to switch on.
BillP Leader
Leader
Yes it is but keep in mind you will still need a 48 volt battery source inline with the ups and solar charger, when there is a peak load your ups will shut off,
ex: an air nailed cant run straight off an air compresses with no tank.
Sir,
