username and password not working after changing IP to static
Showing results forΒ
Did you mean:Β
  • username and password not working after changing IP to static
sinewave47
Crewman sinewave47
Crewman
Posted: β€Ž2021-12-02 01:39 PM
1484
So we just got in a couple of new APC devices to restore some aging units in our environment. However, both a 3kva UPS (SRT3000RMXLT-NC ) and a pair of brand new AP8841 PDUs both have exhibited this behavior when configuring the management card embedded in them.
You use the default credentials, you set new username/password credentials on the card via the web UI, you save the configuration. You then proceed to change the IP configuration from DHCP to STATIC, you save/reboot the card as the UI suggests and then the management card in both these devices come back online with the new IP address intended but whether you SSH or HTTPS to the management cards on them the credentials set no longer work.
The UPS is in Ireland and I'm stateside now I have to pay a tech to go paper clip the brand new UPS and the PDUs in question are local so they will get paper clipped and we will look into flashing them but I know at least for the PDUs they are running new 6.9.6 code right out of the box, is this newer firmware just bad? Are we doing something wrong here, seem strange that something so basic simply doesnt work across a couple different APC device types.
Replies 4
Shaun
Commander Shaun Commander
Commander
Posted: β€Ž2021-12-02 02:15 PM
1475
I'm trying to replicate this myself, using sumx-7.0.4; can you help me spot what I'm doing different to you?
  1. login via ssh and issue 'format, yes, reboot, yes' to get to a clean slate
  2. login as apc/apc, prompted to change my password (per first-boot), and I change it here.
  3. Configuration->Network->TCP/IP->IPv4 Settings
  4. set my IP to Static, IP, netmask, gateway
  5. Control->Network->Reset/Reboot
  6. Reboot Management Interface, Apply, Apply
via these steps I'm unable to reproduce - when the card has rebooted and I login on the new IP, my new password is accepted as expected.
Shaun
Commander
Posted: β€Ž2021-12-02 03:09 PM
1461
I just noticed you mentioned changing the username too - when adding a new user, beware that the Enabled box is not checked by default.
Creating an Administrator without enabling it, and then disabling the superuser (apc) account, is the only way I've managed to paint myself into this corner so far.  I'd strongly recommend logging in with the administrator account before disabling the apc account to ensure it's correctly configured.
If you've found another path to this, I'd love to hear it.  For now .. I need to go find a paperclip ..
sinewave47
Crewman sinewave47
Crewman
Posted: β€Ž2021-12-02 03:10 PM
In response to Shaun
Hi Shaun,
Thanks for the quick reply.
For these configuration attempts we used a web browser (Chrome from Windows 10 PCs) for initial config. Maybe we should be ssh'ing to do this initial setup but using a web browser in the past had worked *shrug* so we gave that a whirl.
So https://ip_of_device
Feed it apc/apc
We then set new credentials first by changing the default admin account password from "apc" to "something_new"
We then created a new local admin account not called "apc" called "usadmin", we set the password on this to "something_new".
We save.
We then change the IP address assignment settings (also from the WebUI interface) from DHCP to manual, we then hit save, the UI then tells us the card must restart and it presents 3 options, We choose Reset/Reboot.
It's very strange.
I'm waiting on local hands to paper clip the 3000 in Ireland and I'll try again with SSH and log each step. We've gotta be doing something wrong here, I'm just not sure what.
sinewave47
Crewman sinewave47
Crewman
Posted: β€Ž2021-12-02 03:13 PM
OHHHHH
OK bulb is slowly illuminating Shaun πŸ™‚
Yes, we never leave the default admin account names in place. I bet this is where we moved too fast and didn't hit the box as you mentioned.
Will watch for this, and try again.
Thanks!
