unable to execute a command file
  • unable to execute a command file
Posted: ‎2021-06-28 08:18 PM . Last Modified: ‎2024-03-15 02:51 AM
890
hi guys!
i have newly installed Smart ups RT 6000 XL with one of my server through serial port. i want to execute a command file. from knowledge base i have found some articles and did following
- used 8.3 naming convention
- changed log on for the ups service
- changed the local security policy for ups service
- also tried using service by "interact with desktop"
but when i click on the test button there is no result as the command file works well manually.
i have simplifed the command file to :
@START c:\windows
otepad.exe
its working fine and opening notepad when i run the default.cmd manually but no result when working through PCBE. its basic version installed and i am accessing the server through remote desktop.
Your suggestions and support will be appreciated.
Best Regards
Abdul Qadir
EZ_Button_apc
Commander EZ_Button_apc
Commander
Posted: ‎2021-06-28 08:19 PM . Last Modified: ‎2024-03-15 02:51 AM
Hi Abdul,
Check your process list after you run that script on 2003. I bet that notepad.exe is running, even though it didn't appear on your screen.
Replies 5
hi abdul,
is this a file a .cmd or a .bat file? try naming it the opposite of whichever that it is.
[here is some reference but it sounds like you already went through all of this..|http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=7712] besides stopping the agent service and restarting?
i forget but have you tried @START "c:\Windows
otepad.exe" with the quotes? have you checked what is inside the default.cmd file? i forget whats in there.
thanks for your reply, i have tried both .bat and .cmd but result is same i.e. no execution but manually the default.cmd is working fine... is there any other work arounds to do..????
best regards
hi,
well it was not working on windows 2003 server, so i connected the serial cable with a pc having windows xp installed and configured the PCBE and it executed the script. It is done !!!!! but what can be the reason for not working in 2003 server what i am thinking can be possibly 2 reasons......
- i was using remote desktop connection as server was not directly connected with any kvm or monitor/keyboard/mouse that was not allowing to execute the scripts through PCBE.
- otherwise it was some security settings that were not allowing executing of scripts...
anyways my problem is solved... thanks for your help and support.
best regards
Abdul Qadir
EZ_Button_apc
Commander
Hi Abdul,
