rPDU Temperature & Humidity Configuration via SSH
  • rPDU Temperature & Humidity Configuration via SSH
wasabi
Lieutenant JG wasabi Lieutenant JG
Lieutenant JG
Posted: ‎2022-10-06 05:09 AM
1055
Hi all,
Just wanted to ask if anyone know the SSH commands to enable the alarm and setup the High/Max for both Temp/Humi and Sensor name via command line with SSH ?
Example model is AP8853
thanks
Shaun
Commander Shaun Commander
Commander
Posted: ‎2022-10-06 05:40 AM
If you run 'help' on the CLI these will all show under 'device commands'.
I believe you're looking for:
humAlGen / humLow / humMin
tempAlGen / tempHigh / tempMax
sensorName
most of these will report the current value if run alone, or set a value if a value is provided.  You can use eg "help tempAlGen" for more detail.
Shaun
Commander
sensorName
