powerchute with BR1500MS attached to Windows Server 2016
Send InviteCancel
Posted: 2021-07-0811:29 PM. Last Modified: 2024-02-1411:52 PM
I have two BR1500MS UPS, one is attached to a system running windows server 2016.
I would like to install PowerChute s/w to manage a controlled shutdown should the power go out.
Personal Edition (which is indicated for BR1500MS) will not install on Windows Server.
Business version (after much hassle) installs, but does not detect the UPS (data port connected to USB using the supplied cable). Seems to want only the 'smart' line and not the 'pro' line.
