pcns 4.3 installation failed
Select a Country
  • pcns 4.3 installation failed
BillP Leader
160
Phil34_apc
Phil34_apc
Contributor
Posted: ‎2021-06-30 04:03 AM . Last Modified: ‎2024-03-08 04:36 AM
2179
I try to install pcns 4.3 on a new machine with centOS 7.6.1810.
Until now, all the installations with pcns 4.2 were a success on centOS7, but the installation with pcns 4.3 fails.
pcns 4.3 messages:
./install.sh -f silentInstall.sample
     PowerChute Network Shutdown 4.3.0 for Linux
     Copyright (c) 1999-2018 Schneider Electric.
     All Rights Reserved.
OS=Linux
Initializing ...
Silent mode input from silentInstall.sample
INSTALL_DIR=/opt/APC
JAVA_DIR=/usr/java/latest/bin/
EULA has been accepted
Creating /opt/APC directory ...
PCNS will be installed to /opt/APC/PowerChute
Checking version of Java ...
Detected Java Version: 1.8.0.221
Acceptable version
java version "1.8.0_221"
Java(TM) SE Runtime Environment (build 1.8.0_221-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.221-b11, mixed mode)
Copying the installation files ...
Extracting PCNS files ...
PCNS is extracted to /opt/APC/PowerChute
Configuring startup files ...
Startup script=/usr/bin/PowerChute
Installing Service ...
Created symlink from /etc/systemd/system/default.target.wants/PowerChute.service to /etc/systemd/system/PowerChute.service.
erreur lors de la lecture d'informations sur le service PowerChute : Aucun fichier ou dossier de ce type
Configure Firewall
Configuring firewalld
Configuring uninstall script ...
Setup the m11.cfg file
Applying Configuration ...
Unrecognized option: --add-opens
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
Error applying configuration.  Error code is: 1
Removed symlink /etc/systemd/system/default.target.wants/PowerChute.service.
Installation cancelled.
We can see: Unrecognized option: --add-opens
pcns 4.2 messages:
     PowerChute Network Shutdown 4.2.0 for Linux
     Copyright (c) 1999-2016 Schneider Electric.
OS=Linux
Initializing ...
Acceptable version
Startup script=/etc/rc.d/init.d/PowerChute
Updating Linux symbolic link ...
Configure Firewall
Registration results ...
Connection to UPS Network Management Card (162.38.134.127) was successful.
Configuration complete.
PowerChute Network Shutdown, v4.2.0
Copyright (c) 1999-2016, Schneider Electric.  All Rights Reserved.
Startup completed.
Installation has completed.
PowerChute Network Shutdown can be accessed through your browser at https://:6547
Please complete the configuration wizard so that PowerChute Network Shutdown can protect your server.
Regards.
BillP Leader
Leader
Posted: ‎2021-06-30 04:04 AM . Last Modified: ‎2024-03-08 04:36 AM
Sorry for the inconvenience. We will look to make a change in a future release.
Replies 5
It will use the wrong JVM. You will need java11, but java8 was called.
Simple set the java home to java11 home.
For that reason I have build me an RPM package. It makes also the mass configuration via puppet much easier.
Phil34_apc
Phil34_apc
Contributor
Thank you Franck.
Il will try tomorrow with the java 11 provided in the tar.gz
Phil34_apc
Phil34_apc
Contributor
I have reinstalled pcns 4.3 vith the private jre 11 and the installation is done correctly.
I appreciate pcns now works with systemd, and I would like to suggest to the developpers adding a warning when pcns detecs the java version 1.8. Currently, it says "Acceptable version".
Regards
BillP Leader
Leader
BDZ
BDZ
Explorer
Posted: ‎2024-06-09 07:40 AM
Hi.
I looking for PCNS 4.3 for my server but APC/SE remove possibility to download this software. If you still have this software can you share with me (maybe by wetransfer or other service)? I specailly looking for linux, windows and VMware version. I will be very happy that users provide better support than manufacturer.
