84275members
353384posts
error inverter ups
Andre_lopes_apc
437
error inverter ups
This was originally posted on APC forums on 1/6/2016
Good morning, I have a UPS here with LED X access and two LED battery indicator access however it does not work
This being the sequence can of leds
1
What should I do?
I need that equipment
Tags (2)
Re: error inverter ups
This reply was originally posted by Tuyishimire on APC forums on 1/15/2016
I have a same problem here, i changed batteries for a working unit but still no changes. what should we do next?
3 Replies 3
mitsmith_apc
Hi Andre,
This fault a lot of times points to bad batteries. How old is the unit and the batteries? Is the unit still powering your equipment?  I would use a volt meter to check the voltage of the batteries. Just measure the DC voltage at the anderson connector for each of the modules. When fully charged they should be 110 volts each. Do you have another unit that uses the same batteries? If so you could temporarily borrow those.
Andre_lopes_apc
This was originally posted on APC forums on 1/7/2016
Was placed second battery of new modules and both with a DC voltage of 108V
PERSISTS EVEN SO THE DEFECT
