Posted: 2021-07-09 04:05 AM . Last Modified: 2024-02-14 11:12 PM
Good morning, have several Switched Rack PDU (AP7900,) recently appeared on one of them in the LED "err", in the log of the web interface is not any error. We have not made any changes and start functioning properly but I would like to know that this is due and whether you can solve. Greetings and thanks
Good morning, thank you very much for responding. The problem was solved automatically. If they occur again inform.
Regards
Hi Eduardo,
If you can still log in, could you please share the event.txt, data.txt, and config.ini files, if they are available via FTP? Instructions here -> http://www.apc.com/support/index?page=content&country=ITB〈=en&locale=en_US&id=FA156131 Alternatively, for event and data logs (event is the most important here), you can view them in the web interface, launch the full log in a new window, and PDF it to review.
I'd also be interested in the first six characters of the AP7900 serial numbers on the devices to gauge the age of the units and any warranty status.
This could be a temporary error that clears by the time as you log in, such as an internal lost communications error. Hopefully the event log will show the error history.
Regards
Posted: 2024-03-06 10:53 AM
I have the same issue:
03/06/2024 04:50:04 Switched Rack PDU: Communications established.
03/06/2024 04:50:04 Switched Rack PDU: Communications lost.
03/05/2024 21:48:31 Switched Rack PDU: Communications established.
03/05/2024 21:48:31 Switched Rack PDU: Communications lost.
03/05/2024 16:14:23 Switched Rack PDU: Communications established.
03/05/2024 16:14:23 Switched Rack PDU: Communications lost.
03/05/2024 13:59:46 Switched Rack PDU: Communications established.
03/05/2024 13:59:46 Switched Rack PDU: Communications lost.
03/05/2024 13:54:36 Switched Rack PDU: Communications established.
03/05/2024 13:54:36 Switched Rack PDU: Communications lost.
03/05/2024 12:49:53 Switched Rack PDU: Communications established.
03/05/2024 12:49:53 Switched Rack PDU: Communications lost.
