can't web login to AP8841
  • can't web login to AP8841
5060
139
Erasmus_apc
Sisko Erasmus_apc
112
Posted: ‎2021-06-28 06:03 AM . Last Modified: ‎2024-03-18 02:51 AM
1787
I have an AP8841. When I attempt to access web console, I get message
ERROR: The application was not able to load
You are attempting to access an APC device.
There was a problem loading the application. please login to telnet for more details.
So I telnet into the device. It's not obvious what's wrong.
Other threads in this forum suggest maybe firmware needs updating. However it looks like I have latest stuff. About gives me this:
American Power Conversion Network Management Card AOS v5.1.2
(c) Copyright 2009 All Rights Reserved RPDU 2g v5.1.0
Name : Unknown Date : 03/27/2011
Contact : Unknown Time : 21:52:26
Up Time : 0 Days 0 Hours 4 Minutes Stat : P+ N4+ N6+ A$
Type ? for command listing
Use tcpip command for IP address(-i), subnet(-s), and gateway(-g)
apc>about
E000: Success
Hardware Factory
Model Number: AP8841
Serial Number: ZA1051026106
Hardware Revision: 02
Manufacture Date: 12/18/2010
MAC Address: 00 C0 B7 55 6F C8
Management Uptime: 0 Days 0 Hours 4 Minutes
Model Number: AP9537
Serial Number: ZA1051010554
Hardware Revision: 05
Manufacture Date: 12/15/2010
Application Module
Version: v5.1.0
Date: Apr 14 2010
Time: 14:50:01
APC OS(AOS)
Version: v5.1.2
Date: Apr 5 2010
Time: 14:03:27
APC Boot Monitor
Version: v1.0.2
Date: Jan 21 2010
Time: 13:35:57
apc>
I'm also confused because this was working fine when we first got the unit, and we've made no firmware upgrades or other changes to the unit.
Posted: ‎2021-06-28 06:04 AM . Last Modified: ‎2024-03-18 02:50 AM
I had the same issue.
reinstalling the firmware using the upgrade utility worked for me as well.
Thanks!
Replies 5
great. and yes, all three files are generally required.
eventlog gives the following response:
E100: Command Failed
Event Log Not Available
I only have access to this system from a linux box. Was there some way that I can update firmware images simply by ftp'ing them to the IP address or something like that?
I ftp'd the apc_hw05_aos_512.bin file to the PDU and I believe it accepted it, because it closed the ftp and when I logged in again it said uptime of 1 minute.
Also the status has changed from A$ to A- Still can't get in via web and eventlog is still unavailable.
Posted: ‎2021-06-28 06:03 AM . Last Modified: ‎2024-03-18 02:50 AM
flashing all 3 files seems to have fixed it!!
Thanks!!
Thanks!
