Posted: โ2025-03-31 05:55 AM
I replaced the batteries today. How can I set the new battery installation date?
Thank you
Posted: โ2025-04-01 06:08 AM
That depends upon the specific APC UPS you have which you havenโt indicated?!?
Regardless, you may use APC Power Chute Software to update the battery installation date (IF) available as referenced here:
https://www.apc.com/us/en/faqs/FA408884/
Questions Ask - If not, and this answered your query please mark this reply as a solution. So it may help the next person asking the same. ๐
Posted: โ2025-04-01 07:18 AM
SMT3000IC
Posted: โ2025-04-01 10:40 AM . Last Modified: โ2025-04-01 10:41 AM
You may use the option I provided via Power Chute Software or these two alternate methods if available or present.
NMC: Configuration -> UPS -> Enter new battery installation date of month / year
LCD: Disconnect the battery cable and wait for the system to declare a battery fault. Wait another ten seconds and than reconnect the battery cable. The system will prompt you to confirm if the battery has been changed. Toggle from No to Yes and enter the month and year.
Next, manually initiate a Self Test and let pass and allow the battery to recover to 100% SOC. Complete the process by manually initiating a *Battery Calibration* with at least 30% attached load to the output. Let this procedure complete and allow the battery recover back to 100% SOC.
Done . . .
NOTE: Mark the actual battery purchase and installation date on the battery cartridge. โ๏ธ
Questions Ask . . . ๐
Posted: โ2025-04-06 10:42 PM
LCD: Scollegare il cavo della batteria e attendere che il sistema dichiari un guasto della batteria...
ok but is it advisable to disconnect the electrical network or can I do it with the UPS on?
Posted: โ2025-04-07 05:07 AM
The UPS can remain on when you disconnect the battery cable.
Posted: โ2025-04-13 09:48 PM
I did as he told me everything is ok but on my account the wrong battery replacement date remains. How can I fix it?
Posted: โ2025-04-14 03:24 AM
Where do you see this being displayed in APC Smart Connect?!?
Posted: โ2025-04-14 09:48 PM
I solved it
thanks
Youโve reached the end of your document
