  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Where Do You Source Your Replacement Fans?
  • Communities
  • Re: Where Do You Source Your Replacement Fans?
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
coastalcruiser_apc
Ensign coastalcruiser_apc
Posted: ‎2021-06-30 09:34 PM
438
This was originally posted on APC forums on 7/20/2016
SMT-1500.
Is it a standard form factor?
Do you just go through an APC distributor, or has someone maybe found a great after market fan that fits (good price, quiet, moves air, long life).
thank you
Goldrush_apc
Crewman Goldrush_apc
This was originally posted on APC forums on 12/14/2016
Thanks Gareth...very helpful indeed . You guys can also check this out.
www.  win-    source.   net
Replies 6
UnexpectedBill_apc
Captain UnexpectedBill_apc
Captain
This was originally posted on APC forums on 7/21/2016
I don't recall the exact size, but the fan itself is a standard form factor. Maybe 80mm?
Two caveats: the fan runs from and is rated for 24 volts DC and it's got a special mounting bracket. As best I recall, the bracket can be attached to another fan. It should simply click into the standard mounting screw holes on the new fan. Unfortunately, there don't seem to be a whole lot of options for replacement 24 volt fans.
coastalcruiser_apc
Thank you William. That is quite helpful. Two vendors I checked with don't carry the fan, but having an inkling it is a std form factor gives me impetus to go ahead and pull the aching one to confirm size and pick up a high quality replacement.
Cheers
This reply was originally posted by Gareth on APC forums on 7/21/2016
I removed my fan to get the model and voltage from the label on it. My SMT2200 had a 92mm 24v fan.
Sunon   Maglev  do 4 speeds in that size and voltage if you can source one, pick the slowest if it is living in a standard temperature  room, medium speeds if the room gets up to 30 degrees and the fastest if it is in an unventilated room.
http://www.sunon.com/tw/products/pdf/DCFAN/ME9225_U.pdf
coastalcruiser_apc
Very helpful Gareth! thank you.
I checked mine today, I bought the ME92252V2-000U-A99 rated at 2700 rpm (it runs at 11.5v at idle lowering the speed) compared to the Y.S Tech FD249225HB rated at 3100 rpm. It is very quiet but at the lower speed it does have a very quiet tick to it that I could hear as it bounced off the wall right into my ear by pure bad luck, if I moved a few inch either way I didn't detect the tick! (fixed today by taping a rubber lies tub over the fan exhaust to direct the airflow down)
As it kicks out enough air I did consider going another speed down as it used to be louder than my water cooled PC at idle, then I bought a HP microserver and that took the lead noise wise so the 200rpm fan can stay!
Goldrush_apc
Additional options
