Posted: 2021-06-26 05:39 AM . Last Modified: 2024-03-19 12:41 AM
We have a weak battery alarm on 40KVA UPS. How can you identify which battery is faulty out of the all the batteries installed?
Regards,E
gives some characteristics of the battery modules that you are using.
I have not worked on a 40KVA. but I have tested the UPS batteries 2KVA, 3KVA, 5KVA. I tested the batteries 12V/5Ah and 12V/7Ah one by one, and by block.
For your case you should remove all the blocks of the UPS battery and test their voltage. if there is a large difference between the measured voltages, the block with the smallest voltage should have faulty batteries, it will replace.
