Posted: ‎2021-06-28 12:03 AM . Last Modified: ‎2024-03-18 11:42 PM
Hi Everyone,
We're just had our inrow unit issue the following alerts:
12.10.2016 | 06:33:14 | InRow RD: Relay output abnormal state no longer exists. |
12.10.2016 | 06:33:12 | InRow RD: Compressor drive communication fault no longer exists. |
12.10.2016 | 06:32:58 | InRow RD: Relay output abnormal state exists. |
12.10.2016 | 06:32:55 | InRow RD: Compressor drive communication fault exists. |
12.10.2016 | 06:32:51 | InRow RD: Controller Reset - Cold Start because of a breakpoint. |
The unit is online with no pending unit/group level alerts. I haven't been able to track down what "cold start because of a breakpoint" actually means. Is this indicative of an issue? Or is it normal/maintenance and can be ignored?
This is an ACRP:
Model Number: | IR25 |
Serial Number: | UK1203113006 |
Controller Firmware: | 4.18.0 |
Hardware Revision: | C8 |
Date of Manufacture: | 01/16/2012 |
VFD software ver.: | 01.07 |
VFD ID Powercard: | SW:01.02 EE:03.23 |
VFD serial number: | 193215G041 |
Thanks in advance!
Hello. This error means that the programming encountered an error and needed to reboot itself to clear the issue. If this has only happened once, keep an eye on the unit and see if the alarm returns. If not the unit is fine and will continue working. If it does come back please call into your local tech support as they can look deeper into exactly what is causing the issue.
Thank you
Thank you
Thanks very much for your prompt response - that is what I suspected, so it is good to hear it. This unit has been up for well over a year (since last service) absolutely rock solid, so I will continue to monitor it for now. If it recurs, I'll reach out to our local tech support
Marcus.
