VMWare ESX Firewall Ports
  • VMWare ESX Firewall Ports
145
Posted: ‎2021-06-30 08:32 AM . Last Modified: ‎2024-03-07 03:01 AM
1119
I am going to be installing the PCNS option for VMWare.
Will the installation automatically open the firewall ports on the ESX 3.5 server or will i have todo this manually?
Janeway
./install.sh
-bash: ./install.sh: Permission denied
I get the error above. I'm logged in as root which to my knowledge is a admin on the server.
*nix requires files to be marked as executable.
chmod a+x install.sh
./install.sh
Replies 4
unfortunately, you have to do it manually. you can use the following which we have tested and should work:
“esxcfg-firewall -o 3052,udp,in,apcups”
“esxcfg-firewall -o 3052,udp,out,apcups”
“esxcfg-firewall -o 3052,tcp,in,apcups”
“esxcfg-firewall -o 3052,tcp,out,apcups”
“esxcfg-firewall -o 6547,tcp,in,apcups”
“esxcfg-firewall –o 80,tcp,in,apcups”
“esxcfg-firewall –o 80,tcp,out,apcups”
“esxcfg-firewall –q”
no quotes of course when entering this in and all of this is case sensitive..
I have done this and now need to install PCNS on the ESX server. I know the server doesnt have Java so i copied these files to the tmp/apc folder "jre150_13_linux.tar.gz", "pcns223.tar.gz" & "install.sh".
I then ran the following commands
gunzip pcns223.tar.gz
tar -xf pcns223.tar
gunzip jre150_13_linux.tar.gz
tar -xf jre150_13_linux.tar
./install.sh
Any idea?
Robin
Janeway
./install.sh
./install.sh
Thanks very much guys.
All seems to be running now.
