User credentials blank when trying to connect to esxi server
  • User credentials blank when trying to connect to esxi server
Posted: ‎2021-06-30 04:51 AM . Last Modified: ‎2024-03-08 03:59 AM
2577
We have installed PCNS using the .ova file for version 4.3.0 build 7951
ESXi - 6.7.0 update 3 Build 15160138
vSphere Client version 6.7.0.42000
we can connect to the vSphere VCenter server using an account called svcapc
we have set the default domain to allow for this account to authenticate without the need to enter the full domain. This authenticaiton is successful.
however when the PCNS tries to communicate with either of the two servers in the cluster managed by the VCenter server, we get the following error:
zxWw%2F%2BMPqSxP5s3BIWPtXw%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.pngzxWw%2F%2BMPqSxP5s3BIWPtXw%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.png
it is as though the user account is not being passed from the PCNS server to the esxi server
can anyone help with this please?
Posted: ‎2021-06-30 04:52 AM . Last Modified: ‎2024-03-08 03:58 AM
Hi Bill,
OK...........so I feel stupid....white space in username.....don't copy and paste is my lesson!
Craig
Replies 9
You need to create the svcapc user with the same credentials on each of the hosts. I have attached 2 links to videos that demonstrate adding a user to vCenter and to a host.
Add user to a ESXi 6.7 host: https://schneider-electric.box.com/s/ataivpmukw6t35fsz8agfc754vwlropo
Add a user to vCenter Server 6.7: https://schneider-electric.box.com/s/3c52nw0509g6ux9zwt4jlb2nt5571tqk
Hi Bill,
yes I have double checked that I have already added the user svcapc to the VCenter and hosts with the same credentials.
What other information do I need to provide that will help?
Craig
Posted: ‎2021-06-30 04:52 AM . Last Modified: ‎2024-03-08 03:59 AM
What is entered in the PowerChute error.log file? Also, what VMware license is on each of the hosts?
Hi Bill,
the VMWare license is 'VMware vSphere 6 Essentials Plus'
03/23/2020 14:05:45 PowerChute cannot locate the vCenter Server VM in the Inventory. See the troubleshooting section in the Online Help.
03/23/2020 14:05:09 Shutdown Host failed for Host 10.20.33.7.
03/23/2020 14:05:06 Shutdown Host failed for Host 10.20.33.8.
03/23/2020 14:04:06 Available runtime has been exceeded.
03/23/2020 14:04:06 Cannot connect to vCenter Server. PowerChute may not be able to issue commands to Virtual Machines or Hosts.
is this what you mean by the error.log file?
Craig
That information is from the event log. The error log will be found in /opt/APC/PowerChute/group1.
Hi Bill,
the formatting is not pretty i am afraid.......
2019-02-01T11:58:22,559 ERROR main com.apcc.pcns.configservice.ConfigurationService - === Starting PowerChute Network Shu tdown 4.3.0 Build: 7951 ===
2019-02-01T11:58:30,716 ERROR main com.apcc.m11.components.StdPowerSource.PowerSourceComponent - No NMC Specified yet. C onfiguration Required
2019-02-01T11:58:32,107 ERROR main com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f:00:00:01:ea: 88:c2:8c
2020-03-23T13:33:01,381 ERROR main com.apcc.pcns.configservice.ConfigurationService - === Starting PowerChute Network Shu tdown 4.3.0 Build: 7951 ===
2020-03-23T13:33:14,271 ERROR main com.apcc.m11.components.StdPowerSource.PowerSourceComponent - No NMC Specified yet. C onfiguration Required
2020-03-23T13:33:14,704 ERROR main com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f:00:00:01:ea: 88:c2:8c
2020-03-23T13:34:50,933 ERROR main com.apcc.pcns.configservice.ConfigurationService - === Starting PowerChute Network Shu tdown 4.3.0 Build: 7951 ===
2020-03-23T13:34:53,518 ERROR main com.apcc.m11.components.StdPowerSource.PowerSourceComponent - No NMC Specified yet. C onfiguration Required
2020-03-23T13:34:54,040 ERROR main com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f:00:00:01:ea: 88:c2:8c
2020-03-23T13:38:41,819 ERROR main com.apcc.pcns.configservice.ConfigurationService - === Starting PowerChute Network Shu tdown 4.3.0 Build: 7951 ===
2020-03-23T13:38:44,422 ERROR main com.apcc.m11.components.StdPowerSource.PowerSourceComponent - No NMC Specified yet. C onfiguration Required
2020-03-23T13:38:44,907 ERROR main com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f:00:00:01:ea: 88:c2:8c
2020-03-23T13:40:57,349 ERROR pool-2-thread-27 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnecti on com.apcc.m11.arch.storage.StorageEntryException: ConfigEntry not found: StdPowerSourceShared.vCenterSerialNumber
at com.apcc.m11.arch.storage.HashPermanentStorage.readData(Unknown Source) - getVCenterPassword() - StorageEntryEx ception:
2020-03-23T13:40:57,353 ERROR pool-2-thread-27 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnecti on com.apcc.m11.arch.storage.StorageEntryException: ConfigEntry not found: StdPowerSourceShared.vCenterTurnOffPoint
at com.apcc.m11.arch.storage.HashPermanentStorage.readData(Unknown Source) - getVCenterUsername() - StorageEntryEx ception:
2020-03-23T13:40:58,270 ERROR pool-2-thread-18 com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f: 00:00:01:ea:88:c2:8c
2020-03-23T13:40:58,727 ERROR pool-2-thread-5 com.apcc.pcns.datagramservice.DatagramTask - java.net.SocketException: Sock et closed
2020-03-23T13:40:59,986 ERROR pool-2-thread-18 com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f: 00:00:01:ea:88:c2:8c
2020-03-23T13:41:28,484 ERROR pool-2-thread-20 com.apcc.m11.components.Omaha.OmahaComponent com.apcc.m11.arch.InvalidObjec tIdException
at com.apcc.m11.arch.datasource.DataBus.get(Unknown Source) - [update] com.apcc.m11.arch.InvalidObjectIdException
2020-03-23T13:41:28,489 ERROR pool-2-thread-20 com.apcc.m11.components.Omaha.OmahaComponent com.apcc.m11.arch.InvalidObjec tIdException
2020-03-23T13:41:29,038 ERROR pool-2-thread-17 com.apcc.m11.components.Omaha.OmahaComponent com.apcc.m11.arch.InvalidObjec tIdException
2020-03-23T13:41:29,054 ERROR pool-2-thread-17 com.apcc.m11.components.PSAggregator.Rules.Redundant.CommEstablishedFiringL ogicRule - com.apcc.m11.arch.InvalidObjectIdException
2020-03-23T13:41:29,054 ERROR pool-2-thread-17 com.apcc.m11.components.Omaha.OmahaComponent com.apcc.m11.arch.InvalidObjec tIdException
2020-03-23T13:41:49,265 ERROR pool-2-thread-36 com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f: 00:00:01:ea:88:c2:8c
2020-03-23T13:42:08,391 ERROR qtp1084663873-51 com.apcc.m11.components.AutoUpdate.SoftwareUpdateChecker_HTTPS - java.net. UnknownHostException: updates.apc.com
2020-03-23T13:42:09,417 ERROR pool-2-thread-29 com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f: 00:00:01:ea:88:c2:8c
2020-03-23T13:48:45,049 ERROR pool-2-thread-40 com.apcc.m11.components.AutoUpdate.SoftwareUpdateChecker_HTTPS - java.net. UnknownHostException: updates.apc.com
2020-03-23T14:00:39,202 ERROR pool-2-thread-32 com.apcc.pcns.SNMP.PcnsBaseAgent - SNMP Agent Engine ID:80:00:01:3e:01:7f: 00:00:01:ea:88:c2:8c
2020-03-23T14:00:43,030 ERROR pool-9-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to pe rform this operation was denied.
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) - Exception caught whi le invoking method: Login
2020-03-23T14:00:43,032 ERROR pool-7-thread-1 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnectio n - ESXiConnectionFailure() - unable to log directly into host: 10.20.33.7 - (NoPermission or InvalidLogin) Permission to perform this operation was denied.
2020-03-23T14:00:48,183 ERROR pool-10-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:00:48,196 ERROR pool-11-thread-1 com.vmware.vim25.ws.WSClient java.net.NoRouteToHostException: No route to h ost (Host unreachable)
at java.base/java.net.PlainSocketImpl.socketConnect(Native Method) - Exception caught while invoking method: Retri eveServiceContent
2020-03-23T14:00:48,207 ERROR pool-7-thread-1 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnectio n - ESXiConnectionFailure() - failed connecting to host: 172.1.30.7 - (RemoteException) Exception caught trying to invoke method RetrieveServiceContent; nested exception is:
java.net.NoRouteToHostException: No route to host (Host unreachable)
2020-03-23T14:00:48,219 ERROR pool-12-thread-1 com.vmware.vim25.ws.WSClient java.net.NoRouteToHostException: No route to h ost (Host unreachable)
2020-03-23T14:00:48,219 ERROR pool-7-thread-1 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnectio n - ESXiConnectionFailure() - failed connecting to host: 172.1.30.9 - (RemoteException) Exception caught trying to invoke method RetrieveServiceContent; nested exception is:
2020-03-23T14:00:48,223 ERROR pool-13-thread-1 com.vmware.vim25.ws.WSClient java.net.NoRouteToHostException: No route to h ost (Host unreachable)
2020-03-23T14:00:48,224 ERROR pool-7-thread-1 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnectio n - ESXiConnectionFailure() - failed connecting to host: 10.20.34.1 - (RemoteException) Exception caught trying to invoke method RetrieveServiceContent; nested exception is:
2020-03-23T14:04:06,438 ERROR Thread-1 com.vmware.vim25.ws.WSClient java.net.ConnectException: Connection refused (Connect ion refused)
at java.base/java.net.PlainSocketImpl.socketConnect(Native Method) - Exception caught while invoking method: Retri eveProperties
2020-03-23T14:04:06,440 ERROR Thread-1 com.vmware.vim25.ws.WSClient java.net.ConnectException: Connection refused (Connect ion refused)
at java.base/java.net.PlainSocketImpl.socketConnect(Native Method) - Exception caught while invoking method: Logou t
2020-03-23T14:04:06,441 ERROR Thread-1 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - is ValidServiceInstance() - unable to connect to vCenter host: 10.20.33.11 - java.rmi.RemoteException: Exception caught tryin g to invoke method RetrieveProperties; nested exception is:
java.net.ConnectException: Connection refused (Connection refused)
2020-03-23T14:04:06,449 ERROR pool-16-thread-1 com.vmware.vim25.ws.WSClient java.net.ConnectException: Connection refused (Connection refused)
2020-03-23T14:04:06,450 ERROR Thread-1 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - vC enterConnectionFailure() - failed connecting to vCenter: 10.20.33.11 - . Exception caught trying to invoke method Retrieve ServiceContent; nested exception is:
2020-03-23T14:04:53,034 ERROR pool-17-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:04:56,112 ERROR pool-18-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:04:56,113 ERROR pool-7-thread-1 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnectio n - ESXiConnectionFailure() - unable to log directly into host: 10.20.33.8 - (NoPermission or InvalidLogin) Permission to perform this operation was denied.
2020-03-23T14:04:59,184 ERROR pool-19-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:04:59,185 ERROR Thread-58 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - isVcsaHostCritical() - cannot obtain HostSystem using findByIP or findByDnsName for critical host: 10.20.33.8
2020-03-23T14:05:03,248 ERROR pool-20-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:05:03,250 ERROR Thread-58 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - isVcsaHostCritical() - cannot obtain HostSystem using findByIP or findByDnsName for critical host: 10.20.33.7
2020-03-23T14:05:06,330 ERROR pool-22-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:05:06,331 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - E SXiConnectionFailure() - unable to log directly into host: 10.20.33.8, (NoPermission or InvalidLogin)
2020-03-23T14:05:06,334 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - E SXiConnectionFailure() - failed connecting to host: 10.20.33.8, (RemoteException)
2020-03-23T14:05:06,336 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - E SXiConnectionFailure() - failed connecting to host: 10.20.33.8 because: Permission to perform this operation was denied.
2020-03-23T14:05:06,337 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - E SXiConnectionFailure() - failed connecting to host: 10.20.33.8 because: Permission to perform this operation was denied.
2020-03-23T14:05:06,338 ERROR Thread-58 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostSystemFromConnec tionToHost() - unable to establish a connection to the host
2020-03-23T14:05:06,338 ERROR Thread-58 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostSystemForHost() - unable to get HostSystem for host: 10.20.33.8
2020-03-23T14:05:09,410 ERROR pool-23-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:05:09,411 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - E SXiConnectionFailure() - unable to log directly into host: 10.20.33.7, (NoPermission or InvalidLogin)
2020-03-23T14:05:09,413 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - E SXiConnectionFailure() - failed connecting to host: 10.20.33.7, (RemoteException)
2020-03-23T14:05:09,414 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - E SXiConnectionFailure() - failed connecting to host: 10.20.33.7 because: Permission to perform this operation was denied.
2020-03-23T14:05:09,416 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - E SXiConnectionFailure() - failed connecting to host: 10.20.33.7 because: Permission to perform this operation was denied.
2020-03-23T14:05:09,417 ERROR Thread-58 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostSystemFromConnec tionToHost() - unable to establish a connection to the host
2020-03-23T14:05:09,417 ERROR Thread-58 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostSystemForHost() - unable to get HostSystem for host: 10.20.33.7
2020-03-23T14:05:09,425 ERROR Thread-58 com.apcc.m11.components.WebServer.util.virtualization.VMware.VMWareConnection - g etESXiHostConnection() - unable to connect to host null
2020-03-23T14:05:14,524 ERROR pool-24-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:05:17,603 ERROR pool-25-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:05:49,159 ERROR pool-26-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:05:54,240 ERROR pool-27-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:05:59,372 ERROR pool-30-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:06:03,451 ERROR pool-31-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:08:07,543 ERROR pool-32-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:08:11,623 ERROR pool-33-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:08:14,714 ERROR pool-36-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
at jdk.internal.reflect.GeneratedConstructorAccessor133.newInstance(Unknown Source) - Exception caught while invok ing method: Login
2020-03-23T14:08:17,793 ERROR pool-37-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:10:22,894 ERROR pool-38-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:10:26,985 ERROR pool-39-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:10:32,083 ERROR pool-42-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:10:36,174 ERROR pool-43-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:10:41,991 ERROR pool-2-thread-9 com.apcc.pcns.SNMP.PcnsTrapGenerator - Errors in the ini file for configura tion of Traps:'SNMP.UPSCriticalEvents_SendClearingTrap' doesn't map to an existing object
2020-03-23T14:12:41,279 ERROR pool-45-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:12:41,287 ERROR pool-44-thread-1 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.7 out of Maintenance Mode
2020-03-23T14:12:45,357 ERROR pool-46-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:12:45,364 ERROR pool-44-thread-2 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.8 out of Maintenance Mode
2020-03-23T14:12:48,446 ERROR pool-48-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:12:53,509 ERROR pool-49-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:14:57,600 ERROR pool-51-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:14:57,608 ERROR pool-50-thread-1 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.7 out of Maintenance Mode
2020-03-23T14:15:02,695 ERROR pool-52-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:15:02,702 ERROR pool-50-thread-2 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.8 out of Maintenance Mode
2020-03-23T14:15:05,774 ERROR pool-54-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:15:10,845 ERROR pool-55-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:17:13,956 ERROR pool-57-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:17:13,963 ERROR pool-56-thread-1 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.7 out of Maintenance Mode
2020-03-23T14:17:17,038 ERROR pool-58-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:17:17,048 ERROR pool-56-thread-2 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.8 out of Maintenance Mode
2020-03-23T14:17:22,119 ERROR pool-60-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:17:25,205 ERROR pool-61-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:19:28,317 ERROR pool-63-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:19:28,325 ERROR pool-62-thread-1 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.7 out of Maintenance Mode
2020-03-23T14:19:31,401 ERROR pool-64-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:19:31,409 ERROR pool-62-thread-2 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.8 out of Maintenance Mode
2020-03-23T14:19:36,485 ERROR pool-66-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:19:41,555 ERROR pool-67-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:21:44,654 ERROR pool-69-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:21:44,661 ERROR pool-68-thread-1 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.7 out of Maintenance Mode
2020-03-23T14:21:49,756 ERROR pool-70-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:21:49,763 ERROR pool-68-thread-2 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.8 out of Maintenance Mode
2020-03-23T14:21:54,843 ERROR pool-72-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:21:59,925 ERROR pool-73-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:24:05,023 ERROR pool-75-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:24:05,031 ERROR pool-74-thread-1 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.7 out of Maintenance Mode
2020-03-23T14:24:09,103 ERROR pool-76-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:24:09,111 ERROR pool-74-thread-2 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.8 out of Maintenance Mode
2020-03-23T14:24:13,184 ERROR pool-78-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:24:17,261 ERROR pool-79-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:26:22,377 ERROR pool-81-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:26:22,385 ERROR pool-80-thread-1 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.7 out of Maintenance Mode
2020-03-23T14:26:27,470 ERROR pool-82-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:26:27,477 ERROR pool-80-thread-2 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.8 out of Maintenance Mode
2020-03-23T14:26:30,560 ERROR pool-84-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:26:33,633 ERROR pool-85-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:28:36,748 ERROR pool-87-thread-1 com.vmware.vim25.ws.WSClient com.vmware.vim25.NoPermission: Permission to p erform this operation was denied.
2020-03-23T14:28:36,757 ERROR pool-86-thread-1 com.apcc.m11.components.Shutdowner.Hosts.ESXManagedHost - getHostsOutOfMai ntenanceMode() - failed to take host: 10.20.33.7 out of Maintenance Mode
So the login is not correct which we know. Where is the config file for the users?
Craig
The user login info is encrypted on the PowerChute VM. It is not saved in a configuration / text file. On the ESXi host the users are save in /etc/passwd and the passwords are encrypted.
A test you can run is to follow the instruction provided in the video for creating a user on a host. Create a new user as shown i.e. powerchute-user being sure to add admin privileges. Then open PowerChute web interface and go the PowerChute Setup. Configure PowerChute for a single host instead of for vCenter. Enter the new user credentials for the host. PowerChute will connect to the host to verify communication. If it fails, you will see an error "Connection error due to invalid logon credential". If it does not fail run a shutdown test to verify PowerChute can power off the host.
If the shutdown works properly create the same user on vCenter and the other host/s.
Hi Bill,
thanks for that very sound piece of advice. Basic Problem Determination...cut out the variables to find the problem.
thanks again....I will post when I find the problem and the solution.
Craig
Hi Bill,
Craig
