Posted: 2021-07-28 09:40 PM . Last Modified: 2024-02-14 02:33 AM
I have a Smart-UPS 2200 RM running on firmware 665.6.I and have just moved offices.
Over the weekend the UPS shutdown the server successfully using PowerChute when the temp got to 32c.
Looking through the log file, when the tmep got under the threshold it started the server again, but then turned off the output power.
Log:
!http://i.imgur.com/aLIzd.png!
How would I go about finding out why the second power off occurred?
I attach the config file (with domains changed).
Message was edited by: andrewleicester
Posted: 2021-07-28 09:40 PM . Last Modified: 2024-01-31 02:56 AM
Also it seems that it was just notifing u it was not because it didnt say : The Power is NOW turned off, it just said the power is off where when it turned the power on it said " The output power is now on"
The logs only appear to show that the power turned off once (at 11:43:33). The NMC warmstarted at 11:55:04 and at startup, reported that the power was still off at 11:55:35. Then eventually the power turned on at 08:58:08.
can you provide the data log too for this time period? how about the event log from the powerchute network shutdown client at 200.10.10.2? and did you manually turn the output back on the on the 4th?
