UPS: Battery charger failure - Why ?
  • UPS: Battery charger failure - Why ?
Posted: ‎2021-06-30 01:30 AM . Last Modified: ‎2024-03-11 01:19 AM
1484
My UPS tells me the following errors:
02/13/2012 11:36:10 UPS: Battery charger failure cleared.
02/13/2012 11:36:05 UPS: Battery charger failure.
What should I do?
thank you
Informations :
Model: Smart-UPS RT 10000 XL
Firmware Revision: 476.14.W
Manufacture Date: 01/18/06
Serial Number: JS0604010332
It's hard to say as it only happened once. If it occurred several times, it would of course indicated a problem with the charger however I've seen in the past to be a UPS firmware issue although you would see SEVERAL charger faults if that was the case. I would recommend you keep an eye on it and if it continues to happen, you can reply here or call your local tech support and they can help you further.
Are these the only two messages regarding the charger you have received?
Thank you for your response.
In one month of log, this is the first error.
Thank you
