Symmetra PX display gets all wonky when the load is turned on.
Send InviteCancel
Posted: 2025-08-1405:46 PM
Have a 20kw Symmetra PX, the display and menus work ok if the UPS output is off, but once you turn the output on the display acts like its not its not receiving data and is very slow.
The load and battery will just turn to dashes, and if you look under status any data will be blank such as the voltage. if you wait a bit it does eventually show up.
I have swapped out the display, display card, removed the network card etc nothing seems to help, I can get a photo tomorrow.
