84437members
353635posts
Switched PDU
179
Switched PDU
This question was originally posted by Luis Fernando on APC forums on 6/18/2015
Hi, I have an AP7900 Switched PDU, and I was wondering if it's possible to configure a sequential OFF triggered by an event of power loss in the UPS powering the PDU.
On the other hand, I want to know what triggers the ON and OFF Delay configured per outlet on the Configuration Tab?
Re: Switched PDU
This reply was originally posted by Angela on APC forums on 6/18/2015
Hello Luis,
Yes, Power on/off delays under Configuration tab will apply when input power is applied to the PDU from a cold start  (like when the UPS powering the PDU turns off and back on again) and it also applies if you select the on-delayed or off-delayed commands within the PDU itself. You can bypass those if you select on-immediate or off-immediate.
I hope this clarifies. Let us know if you have further questions.
1 Reply 1
Re: Switched PDU
Hello Luis,
