Suspected fatal error
  • Suspected fatal error
5060
142
Posted: ‎2021-06-28 05:49 AM . Last Modified: ‎2024-03-18 03:14 AM
1193
Working for a remote school that has just been donated a 3000XHV UPS.
However on power up all 5 LEDs flash simultaneously red.
The right most LED  flashes a split red/green light.
The manual indicates that this is a an internal error requiring a return to support agents.
Could someone confirm this diagnosis?
  • error
  • fatal
  • flashing
Posted: ‎2021-06-28 05:50 AM . Last Modified: ‎2024-03-18 03:05 AM
Hi Pius,
You should call local support for assistance. Local support contact information can be found at this link. http://www.apc.com/ug/en/support/contact-us/index.jsp
Replies 6
Posted: ‎2021-06-28 05:50 AM . Last Modified: ‎2024-03-18 03:13 AM
Hello Geoff,
Would it be possible for you to provide the exact model number of your unit? It can be found at the back of your unit printed on a white barcode sticker. Can you also include a photo of the front panel for us to better determine the issue?
Hello Team,
I'm called Pius Mande, A technician with Macos (U) Ltd of uganda. I have a ups APC MGE 120kva ups which is giving me the error 7-5-1 (Cable disconnected) and it is failing to start. They were two machines working in parallel and i transfered one to another bank data centre but am now facing that problem. what can i do?
Hello Pius,
The UPS that you are using seems to be a 3 phase unit. Would it be possible for you to create a new thread under the 3 phase category? Unfortunately, I am capable of handling single phase and not 3 phase units.
Thanks for your interest
Model: 2130-RU1
Brand: IBM
SN: 23Z1400
Hope this helps.
Geoff
Hi Geoff,
That model is built by our competition. http://powerquality.eaton.com/ibm/US/Products/ups3000-obsolete-specs.asp
Hi Pius,
