SY96K160H & Modbus/ dry relay contacts integration
  • SY96K160H & Modbus/ dry relay contacts integration
Posted: ‎2021-06-26 03:42 AM . Last Modified: ‎2024-03-19 01:40 AM
1125
There are a few SY96K160Hs in LANs, but it is needed to monitor the system via dry relay contacts and RS-485 ( modbus protocol).
So I wonder,
1) if there is a card to provide some kind of signals and what signals we'll get - please send a table or a link?
2) If we use AP92200 ( ISXM) with modbaus integration (APPLICATION NOTE #70) , then what signals excactly we get?
3) If we install AP9619 in SY96K160H, then what signals we'll have from output contacts?
4) Is it possible to get RS-485 connection directly from SY96K160H
Any other ideas or hints are highly welcomed.
Thank you in advance.
  • Data Center & Facility 3 Phase UPS
Janeway
As an addendum to my last message, the UPS modbus map for all UPSes is in this appnote:
[UPS Modbus Map|http://www.apcmedia.com/salestools/JRUK-63SRXH_R2_EN.pdf]
Modular distribution, if purchased with the PX2, is also available via Modbus, however I don't see a Modbus map listed on the web. Feel free to message me if you need any help with modular distribution on Modbus.
The built-in dry contacts on the PX2 can be triggered by these UPS conditions:
* Any UPS Warning Alarm
* Any UPS Critical Alarm
* UPS On Battery
* On Battery & Low Battery
* Replace Battery
* System in Bypass
* Switchgear Alarm
* UPS is Overloaded
* UPS Output OFF
* UPS Load Alarm
* UPS Redundancy Alarm
* UPS Runtime Alarm
Additionally, if you have modular distribution, you can trigger on:
* Maximum/high/low/minimum module/subfeed/system current
* Module breaker position
* Maximum/high/low/minimum subfeed/system voltage
* Subfeed/system frequency
If the UPS has environmental monitoring (I'm not sure if this comes with it), then temperature and humidity probes can trigger the contacts as well.
Replies 4
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
It doesn't look like the MegaWatt is capable of using smart slot cards.
However, if you can, there is a Modbus/JBus card:
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=AP9622
Thank you,
Why it doesn't look like the SYPX 2 is capable of using Smart slot cards?
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=SY96K160H
The web site says that the UPS includes Web/SNMP Management Card
I wonder what data excactly the card ( AP9622) will send from the particular UPS ( PX-2)?
Why not to use ISXM or ISXC?
Janeway
PX2s have dry contacts that can trigger on a wide range of conditions, from various output voltage and current conditions on subfeeds, modular distribution breakers, as well as the UPS conditions. The Web/SNMP module firmware also enables ISX Manager to expose much of this information over Modbus.
I apologies for being vague on the exact capabilities... I'll know more on Tuesday when I go back to work.
Janeway
* UPS On Battery
* Replace Battery
* System in Bypass
* Switchgear Alarm
* UPS is Overloaded
* UPS Output OFF
* UPS Load Alarm
* UPS Runtime Alarm
