SURT10000XLT Run-time calibration
Send InviteCancel
Posted: 2021-06-3010:53 PM. Last Modified: 2024-03-0603:35 AM
SURT10000XLT, SN:NS0623003696
Rack mount unit with 4 XR battery cabinets, with a total of 10 recently replaced RBC44 battery modules. The unit is not reporting the correct run-time. It's backing up some critical equipment that we are un-able to shut down so we would like to re-set the battery constant as outlined in the APCUPSD manual. We've been successful in doing this before, on smaller SU's, using the values in the manual. There isn't a value listed for an SURT10000XLT but there is one for an SURT10000XLI. Can I use the XLI value for the XLT? If not can you PM me the correct value?
